Aeromotive Introduces True Variable Speed Fuel Pump Controller
By Chris McWilliams January 30, 2020
New from Aeromotive – the True Variable Speed (TVS) Controller for its line of brushless gear fuel pumps. This controller adjusts the pump speed to improve fuel system efficiency reduce fuel temperatures. See more details below.Official Release:
Aeromotive, the leading manufacturer of aftermarket fuel systems and accessories, has released its new True Variable Speed (TVS) Controller (PN 18047) for its line of brushless gear fuel pumps. This controller adjusts the pump speed to improve fuel system efficiency reduce fuel temperatures.
Utilizing a 0-5-volt DC analog input from the ECU or the vehicles Throttle Position Sensor (TPS), Aeromotive’s new TVS Controller decreases fuel pump speed during low-demand periods, reducing current draw and cycle rate resulting in cooler fuel temperatures.
The TVS Controller is designed to work with all 3.5 and 5.0 GPM in-tank and inline gear pumps in the Aeromotive Brushless line. The new TVS Controller is available pre-installed on all new Aeromotive Brushless 3.5 and 5.0 GPM Fuel Pumps and can be retrofitted to any Aeromotive brushless gear pump purchased prior.
The TVS Controller and all Aeromotive pumps are backed by Aeromotive’s one-year limited warranty.
Features:
- Adjusts pump speed to improve fuel system efficiency
- Reduces fuel temperatures
- Designed to work with all 3.5 and 5.0 GPM in-tank and inline gear pumps in the Aeromotive Brushless line
Article Sources
Aeromotive
https://www.aeromotiveinc.com
(913) 647-7300
Drag Racing
4
Nov 3, 2019 05:38 PM
American Iron Tech
4
Sep 6, 2019 02:41 AM
Drag Racing
4
Aug 1, 2019 05:44 PM
