Labonte Alky/Meth Kits!
Old Oct 13, 2008 | 08:53 AM
1320 Engineering's Avatar
Default Labonte Alky/Meth Kits!
Labonte Alcohol Injection Kit [ISG-10]
Description:
The ISG-10 from Labonte Motorsports provides a cost effective way to lower intake air temperature and increase fuel octane through alcohol injection. Designed for gasoline engines, the ISG-10 allows for higher boost levels or increased engine timing on pump gas. The ISG-10 is compatible with all Labonte MotorSports Injection Controllers and Monitoring Systems. Make the power you want without using expensive C116 race fuel !
Features:
• Alcohol safe 150psi Pump
• 2qt Fluid Tank
• Includes FCS-10 Flow Control Solenoid
• High Atomization Injection Nozzles
• 15 feet high pressure hose
• Complete Install Instructions
• Easy Installation and Setup
• 1 Year Warranty
3D Injection Dash Display [VCS3D]
Description:
The VCS3G from Labonte MotorSports is not just an injection controller. It is a fueling computer for water-methanol injection systems. The advanced control algorithm was developed through rigorous engineering and dyno testing to deliver precise control of injection. Delivering the right quantity at the right time leads to maximum horse power and detonation control from an injection system.
Features:
• User friendly-system "tunes" itself. Simply enter pump type, boost start point, nozzle size, and approx HP - and the correct injection quantity is configured from the units 3D injection algorithm
• True 3D injection control based on engine fueling and boost pressure for maximum power and the most accurate injection at all times
• Injection Fail Safe input displays actual injection qty on screen and warns if injection goes below set-point for enhanced reliability
• Adjustable on-the-fly for additional fine tuning (+ or - of the injection map) from the drivers seat
• Internal MAP Sensor reads 0-30psi
• Fluid Level switch input and warning indicator/beeper
• Advance LCD and touch screen control panel allows easy setup, tuning and monitoring of system, all on the fly in real-time
• Displays Injector Duty Cycle, Boost (psi/bar), % water-methanol injectoin, warning indicators for low-flow or low fluid level (with optional upgrades)
• Extensive System Diagnostics for error free usability
• Peak & Hold displays Max Boost, IDC and Injection
• Additional 12V output signal for running nitrous, etc.
• Includes: Dash Display Module w/mounting bracket, engine bay injection controller, Laptop cable to update flash memory, wire harnesses for complete install.
• Designed to operate on Fuel Injected gasoline engines with Forced Induction (Turbo or Supercharger)
• 1 Year Warranty
Boost Activated Controller [VC-25D]
Description:
The original VC-25 designed and manufactured by Labonte MotorSports has been the choice controller used by other water-methanol injection companies for years. Based on progressive load based injection technology, the VC-25 delivers performance that Tuners have come to know and trust. The easy set and forget control strategy makes the VC-25 an ideal water-methanol injection controller for Turbo and Centrifugal Supercharged forced induction engines.
Features:
• Make more Power and lower EGTs with Variable Control
• Controls Injection Pressure as a function of Boost
• Fully Integrated MAP Sensor 0 to 30 psi
• Potted Electronics and Rugged Design for Under Hood Applications
• 1.5% Maximum Error over 0° to 85°C
• Easy Adjustment and Setup
• Ideal for Turbo and Centrifugal Supercharged Engines
• 1 Year Warranty
Boost/Maf Activated Controller [VC-25D]
Description:
The VC-25D from Labonte MotorSports is engineered to reliably operate Shurflo based alcohol injection systems on turbo Mitsubishi,
Dodge and some Chrysler engines. The controller will increase injection pressure over a user adjustable range and quickly shut off when
boost pressure drops to prevent misfire. 2D control from Boost and MAF signals results in accurate injection for fast spooling turbos.
The small rugged design and easy setup makes the VC-25D the logical choice for automotive/offroad enthusiast.
Features:
• Controls Injection Pressure as a function of Boost and MAF
• Ideal for Mitsubishi, Dodge and some Chrysler Turbo Engines
• 1 Year Warranty
Failsafe [IFS-10]
Description:
The IFS-10 unit by Labonte MotorSports is designed to ensure reliability for highly modified performance vehicles using Alcohol Injection Systems. The unit can detect faults and will output a 12 volt trigger signal in the event a fault occurs. The Injection Fail Safe unit has an internal flow meter the can measure flow from 100ml/min up to 2.5L/min.
Features:
• Compatible with 100% Methanol
• Real Time 0-5volt Flow output signal
• User Adjustable Flow Trigger Point
• 1 Year Warranty
Digital Injection Flow Gauge [IFG-20 & IFG-30]
Description:
Need to know your flow? Labonte MotorSports has the answer. The IFG-20 is a 52mm gauge that can be used with the Injection Fail Safe (IFS-10) to display fluid flow in Real Time. The built in Peak & Hold feature lets you recall the last maximum injection flow rate. No more guess work when tuning to know your systems injection output.
Features:
• 3 Year Warranty
• High Brightness Red or Blue Display
Boost Bypass Kit [BBK-20]
Description:
When used with the Injection Fail Safe (IFS-10), the Boost Bypass Kit will limit Turbo vehicles to wastegate boost pressure in the event the IFS-10 detects any system faults. The fast acting 3-way solenoid adds an additional level of safety for highly modified engines with water/methanol injection.
Features:
• Fast Acting 3-Way Solenoid
• Compatible with Manual or Electronic boost control devices
• 1 Year Warranty
Fluid Control Solenoid [FCS-10]
Description:
This fast acting 100% methanol compatible solenoid is ideal for instantaneous nozzle response. Manufactured from 303 Stainless Steel, and can flow over 2500ml/min. Designed to be installed between the injection pump output and nozzle(s). Recommend for applications where fluid tank is installed higher then nozzles, or nozzles installed after throttle plate or carb butterflies. Comes with 2 1/4" hose push-to-connect fittings. Compatible with all Labonte MotorSports injection controllers.
Dual Nozzle Setup [NDU-10]
Description:
For any application that requires a second nozzle. Either higher horse power where one nozzle is not enough, or two smaller nozzles to match injection needs exactly. Kit includes Nickle plated T fitting, second nozzle holder and 3ft of additional high pressure hose. Note - Injection Nozzle not included.
Fluid Level Switch [FLS-10]
Description:
Methanol compatible float style level switch that can easily be installed in any fluid tank. The included Amber LED can be installed in the dash or a gauge pod for visual indication of low fluid.
PM For Pricing!!!!
1320 Inc./////
Call - 813-842-0505
Email Info@just1320.com
http://www.just1320.com
8602 Temple Terrace Hwy. C-14
Tampa FL 33637
4ws tuning
Boost Lab
Old Oct 16, 2008 | 06:07 PM
ghostofnyc's Avatar
N20 Whore
nice looking kit can you run 100% meth throught it?
F.D.L.R / Midnight Auto/ Induction Performance
RIP BOOGA
When the Green Light Drops the Bullshit Stops.
ALPHA TUNING For all of your tuning needs 813-443-5064 http://www.inductionperformance.com/
Old Oct 16, 2008 | 07:04 PM
yep 100% meth is not a problem
its being run on quite a few customers' cars reliably
1320 Inc./////
Call - 813-842-0505
Tampa FL 33637
4ws tuning
Boost Lab
Old Oct 20, 2008 | 10:07 PM
1SlowEvo's Avatar
great kits that are reliable
Old Dec 4, 2008 | 03:42 PM
nobody wants a labonte kit?
1320 Inc./////
Call - 813-842-0505
Tampa FL 33637
4ws tuning
Boost Lab
Old Feb 18, 2009 | 06:45 AM
check out the new labonte kit on our website
1320 Engineering - Labonte Alky/Meth kit
adding parts daily!
1320 Inc./////
Call - 813-842-0505
Tampa FL 33637
4ws tuning
Boost Lab
Old Apr 1, 2009 | 09:12 AM
LUCKY05's Avatar
I want one
1320Engineering/////
Originally Posted by blue del sol
to the boosted is300 ... that handed me my ass tonight....
props, mad props.
Old Apr 2, 2009 | 11:42 AM
Originally Posted by LUCKY05
I want one
you're gonna need it! haha
let me know when you're ready
1320 Inc./////
Call - 813-842-0505
Tampa FL 33637
4ws tuning
Boost Lab
Old Apr 7, 2009 | 02:31 PM
nismo's Avatar
BRB
Meth!!
