Resolving your Bad Idle (KA Engines)
Old Apr 15, 2004 | 09:55 AM
MaxType 240's Avatar
All Around Maxed
Default Resolving your Bad Idle (KA Engines)
So many people have idle issues and this is the most common solution. It took me about 30min to do but I have small hands.
Here's the IACV:
http://www.geocities.com/motorcity/s...y/5167/iaa.jpg
The pic is taken from the rear. To find it from the passenger side, proceed to the end of the intake manifold and look under the EGR piping.
0. Remove vacuum line.
1. Disconnect IACV-FICD harness (purple, be careful).
2. Unscrew IACV-FICD solenoid (don't drop anything)
3. Remove 10mm bolts (there are 4).
4. The 4th is under the solenoid in the pic.
5. Remove gray connector harness.
6. Remove IACV housing, clean w/ carb cleaner. Remove idle adjustment valve and clean out as well.
7. Gasket will crumble apart. Scrape away all residue.
8. Carb clean inside the manifold port, wipe away with cloth.
9. Re-gasket and re-assemble.
Adjust Idle:
1. Have the car warmed up
2. Disconnect the TPS harness
3. Turn the idle adj. screw on the IAA to get the car to idle at 650 rpm.
4. Reconnect the TPS harness and your car should purr at 700 or so rpm. (The Factory manual gives a +/- tolerance of 50 rpm).
Hope this helps you all out,
Jesse
Ings RSpec, Built KA24DET, GT3071R
VR-4 AWD/TT Winter Sled
Old Apr 15, 2004 | 11:00 AM
Jeff240sx's Avatar
Cpt. Negative
Great info! Seeing as I'm about to do this anyway. How did you order the gasket for the IACV? When I called Nissan, they needed my VIN number because they have 4 IACVs...
-Jeff
edit: And the pic doesn't work. (at least for me...)
** This space reserved for someone else's witty quote **
Old Apr 15, 2004 | 11:11 AM
SILVIA-S14's Avatar
Suck A Turd!
Couple of questions:
1) I was under the impression that we had to remove the Intake manifold (Top part atleast) to get access to IACV and its removal? TRUE ? FALSE?
2) Can all this be accessed and done from engine bay or do I need to Jack the car up on jackstands to get the IACV out from the bottom?
Thanks Jesse for the info…….The pic is not working for me though…..I’ll look into the FSM for a picture.
Thanks
RINKU
FOR SALE ITEMS
http://picasaweb.google.com/10373888.../FORSALEITEMS#
1) BRAND NEW XBOX 360 4GB. (Never Opened - Factory Sealed)
2) TI 89 Texas Instruments GRAPHIC CALCULATOR. Barely Used.
3) Dell Vostro 200 DESKTOP Complete PC Package.
Click link above to see PHOTOS & CONTACT INFO.
I am in WESLEY CHAPEL, FL area and can meet locally. SEE ITEM in person before you buy for peace of mind.
Old Apr 15, 2004 | 11:14 AM
SILVIA-S14's Avatar
Suck A Turd!
Default Re: Resolving your Bad Idle (KA Engines)
6. Gasket will crumble apart. Scrape away all residue.
8. Re-gasket and re-assemble.
So a regular grey liquid gasket maker thing i am assuming? No actual physical gasket from a dealer needed?
Thanks
RINKU
FOR SALE ITEMS
Old Apr 15, 2004 | 11:26 AM
SILVIA-S14's Avatar
Suck A Turd!
I found this thru FA....
http://www.imagestation.com/picture/...d/fb937b69.jpg
http://www.geocities.com/MotorCity/S...5167/help.html
RINKU
FOR SALE ITEMS
Old Apr 16, 2004 | 09:57 AM
All Around Maxed
-Jeff
Jeff, you're kidding right? Buy some 800 degree liquid gasket from your local auto store for $4. It'll serve you well for a lot of projects...
Old Apr 16, 2004 | 12:50 PM
Shadytrixta1's Avatar
has whippled VTEC
i did this on my car about three times trying to fix my idle.It is possible to do it without removing the intake manifold as long as you got a pair of small hands around, and lots of patience.To add to your idle problem list mine was caused by the actual intake manifold gasket itself.The one between the head and the manifold.
Old Apr 16, 2004 | 12:57 PM
Jeff240sx's Avatar
Cpt. Negative
Thats always the first place to look.. any excess air not metered by the MAF will cause an idle issue. The IACV falls into this category, and the KA has a miserable time with it. Generally carb cleaner does the trick on an IACV...
And Jesse, I generally try to get a paper gasket (dunno.. more OEM??) before resorting to permatex. I just don't know when to use hardening gasket goo and nonhardening.
-Jeff
Old Apr 16, 2004 | 01:42 PM
Jonas's Avatar
Rinku, did you fix your problem?
Jonas
Old Apr 16, 2004 | 08:18 PM
SILVIA-S14's Avatar
Suck A Turd!
No not yet Jonas........
Been driving the Silvia......
Got Z fest tomorrow......SUnday i gotta study up for my final exam on Monday.......so we'll see how it goes after that......Just driving the silvia for now......it don't get out much otherwise, this gives it a good reason to be out more.......
Besides i got fat fingers and big hands and very little patience.....heheheh
RINKU
FOR SALE ITEMS
