Sponsored by: CARiD
need suggestions on boosting
Old 06-15-2009, 10:02 AM
cant slide
markstheman365's Avatar
Default need suggestions on boosting
my boy has a 91 celica and i have a 93 mx6 swapping in a klze, and my other boy has a 96 mx6 swapping in a klze, as for the mx6's we are changing out stock injectors with milenia s injestors, but what else should we do for the 6's. we are only gonna run 4-7 psi MAX! next i have no idea what we should do with the celica we have a kit, but the motor has 260k on it. what should we do to prepare it. the motor is a 1.6 i believe its the st model. plz lemme know what to do, thx alot
contact admin@tamparacing.com to advertise on here.. - mod
Old 06-15-2009, 11:21 AM
'95hatchCivic's Avatar
the celica engine is a grenade
Old 06-15-2009, 11:40 AM
cant slide
dam for real, shitt, well what should we do cuz its a slow ass grenade
Old 06-15-2009, 11:46 AM
what year celica
Old 06-15-2009, 12:34 PM
Turn 7 at Sebring
RoadRacer's Avatar
moving to the power adders section.
Patrick -
Old 06-15-2009, 12:35 PM
pfft.....
Garrett's Avatar
dont take this the wrong way but only planning on boosting 4-6 PSI WTF thats not even worth it. You could get the same benifits by doing a weight reduction.
Old 06-15-2009, 12:39 PM
^haha true hes just in it for woosh noise and spew spew in between shifts
nah for real build the block run a 50trim and tune it add supporting mods like fuel and ignition and youll have a fast car it takes money to go fast and a little money to go boooooooooost booooooom. then no car so money wasted
Old 06-15-2009, 03:18 PM
PSSHHH x2
Sneakin Deacon's Avatar
dont take it the wrong way...but technically, cars could pick up 100, 200, or even more power with just 4-6psi.
El Pendejo Loco
2002 Suzuki Hayabusa
1507 "dry" block
Brocks megaphone
Spencercycle 10" swingarm
MPS auto shifter
Hays convertible clutch
Yea, that about sums it up...
Old 06-15-2009, 03:21 PM
PSSHHH x2
make sure the mil injectors are enough flow for even your meager goals, boost referenced timing, fuel pump, boost referenced variable rate fuel regulator, and if your car is a MAF equipped car, you may have issues since your obviously planning to vent the valve to the atmosphere and not recirculate. even boosting it cheap to give it some sort of longevity isn't going to be really cheap. may as well run a T25 or find a 14B of a dsm
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
