how do u change oil pump in ka24de
Old May 3, 2009 | 10:03 AM
atownnismo240's Avatar
nissan 4 lyfe
Default how do u change oil pump in ka24de
hey like title says i need the easyest way to change oil pump
Old May 3, 2009 | 11:55 AM
180SX's Avatar
by either
1. pulling the motor
or
2. trying to get it out in the car by dropping the cross member / supporting the motor / pulling the pan / valve cover / front cover
martin
ps..
option 1 is a lot easier
Old May 3, 2009 | 11:59 AM
nissan 4 lyfe
thanx ill try dat
Old May 3, 2009 | 12:04 PM
nissan 4 lyfe
am i able to just take the cover off or do i gotta pull all the timing off to
Old May 3, 2009 | 07:52 PM
ralph.'s Avatar
Your resident TR cokehead
u dont have to pull the timing off. the pump is the lower front cover. you will notice the 4 or five phillips head screws on the inside of the lower cover. that would be it. but as martin said it would really be easier to pull the motor.
For 20 dollars ill call the guy a chicken fucker!!!!!!!
Old May 3, 2009 | 08:39 PM
Speed cat's Avatar
speed cat
dude, pull the motor, it will save you ALOT of time. and it is a pain in the ass to get the cross member and shit all back bolted in place by yourself.
Old May 4, 2009 | 05:37 AM
nissan 4 lyfe
aight tru dat i gotta pull the motor neways but ye aight thanx everybody i appriciate it
Old May 4, 2009 | 06:26 AM
nissan 4 lyfe
Old May 4, 2009 | 06:52 AM
sean1's Avatar
i has double turbo
theres also 2 you gotta get from under the valvecover
my honda sounds like a lawnmower, because it is one.
Old May 4, 2009 | 07:35 AM
ralph.'s Avatar
i was stating about the ones on the back of the bottom cover like it states. to remove the oil pump componets thanks thou.
