+ Reply to Thread
Page 3 of 3 FirstFirst 1 2 3
Results 31 to 43 of 43
  1. #31
    [IMG]http://i950.photobuc SilviaKid is an unknown quantity at this point
    Join Date
    Jan 2010
    Location
    st. pete
    Posts
    275
    Feedback Score
    2 (100%)
    looking good justin ill come check it out soon bra
  2. #32
    Registered User bikeimports has a reputation beyond repute bikeimports has a reputation beyond repute bikeimports has a reputation beyond repute bikeimports has a reputation beyond repute bikeimports has a reputation beyond repute bikeimports has a reputation beyond repute bikeimports has a reputation beyond repute bikeimports has a reputation beyond repute bikeimports has a reputation beyond repute bikeimports has a reputation beyond repute bikeimports has a reputation beyond repute bikeimports's Avatar
    Join Date
    Jun 2007
    Posts
    669
    Feedback Score
    1 (100%)
    Got the sending tube welded in and closed the tank:
    Move onto getting everything setup so I can run the new lines, got the pump where I wanted it, cut a hole, got a body plug so it does chafe and painted to prevent any rust:
    Just need to get the appropriate hoses for the tank feed/return and vent.....
    I moved up front to try and clean up this mess and come up with a solution to that ridiculous fuse box, some more foolishness I encountered:
    Removed the battery tray & fuse box and hit the area with some purple power:
    I'm left with this mess to relocate open to suggestions as to where I should place it:
    Decided in the mean time to start my hot side charge piping and realize I ran out of tight radius elbows
  3. #33
    JDM cavaliers KendallH has a reputation beyond repute KendallH has a reputation beyond repute KendallH has a reputation beyond repute KendallH has a reputation beyond repute KendallH has a reputation beyond repute KendallH has a reputation beyond repute KendallH has a reputation beyond repute KendallH has a reputation beyond repute KendallH has a reputation beyond repute KendallH has a reputation beyond repute KendallH has a reputation beyond repute
    Join Date
    May 2009
    Location
    Largo
    Posts
    522
    Feedback Score
    1 (100%)
    A lot of people relocate that fuse box under the airbag panel on the pass side under the dash. Hidden + easy access. Should be some good info in here: the wire tuck pic thread - Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum
  4. #34
    Join Date
    Jun 2007
    Posts
    669
    Feedback Score
    1 (100%)
    Thanks Kendall
  5. #35
    Join Date
    Jun 2007
    Posts
    669
    Feedback Score
    1 (100%)
    Did a few little things:
  6. #36
    Join Date
    Jun 2007
    Posts
    669
    Feedback Score
    1 (100%)
    Had a brief delay.. to get work done on customers cars, but got some spare time in and between:
    wanted to start on my piping, did the hot side first...
    Hotside piping is 3"
    Installed my fuel pressure regulator on the firewall:
  7. #37
    Join Date
    Jun 2007
    Posts
    669
    Feedback Score
    1 (100%)
  8. #38
    Join Date
    Jun 2007
    Posts
    669
    Feedback Score
    1 (100%)
    Started the cold side: 90mm TB4" piping4" Vibrant vanJen Clamp4" vibrant silicone coupler (for flex)
  9. #39
    Join Date
    Jun 2007
    Posts
    669
    Feedback Score
    1 (100%)
    Finished tacking up the coldside piping:
  10. #40
    Registered User Noah2JZ is an unknown quantity at this point
    Join Date
    Sep 2011
    Posts
    119
    Feedback Score
    lol that shit is massive
  11. #41
    Join Date
    Jun 2007
    Posts
    669
    Feedback Score
    1 (100%)
    And for some motivation, I had a friend of mine render this image for me, Close to the look I'm going for minors the wheels going for gold work vsxx we'll see what happens.. anyways If anyone needs any graphic design work done on cars, He does great work & Is currently designing graphics for a formula D drift car.
  12. #42
    Join Date
    Jun 2007
    Posts
    669
    Feedback Score
    1 (100%)
    Well it's been a long time, I've been very busy with the shop and no real time to work on the 240. I've made some time recently and plan to get the ball rolling again,
    I made a decision to go manual instead of automatic which is unfortunate considering I had the drive shaft and tranny mount already made, but i believe it will be better on the street side of things as a manual:
    V160 6spd transmission / RPS clutch:Working late removing the stock cams to installing the BC springs and 280 cams:
  13. #43
    Registered User 91180sr has a reputation beyond repute 91180sr has a reputation beyond repute 91180sr has a reputation beyond repute 91180sr has a reputation beyond repute 91180sr has a reputation beyond repute 91180sr has a reputation beyond repute 91180sr has a reputation beyond repute 91180sr has a reputation beyond repute 91180sr has a reputation beyond repute 91180sr has a reputation beyond repute 91180sr has a reputation beyond repute 91180sr's Avatar
    Join Date
    Aug 2006
    Location
    St.Pete
    Posts
    868
    Feedback Score
    2 (75%)
    Beastttt
    04 z33 Track- N/A
    91 180sx-
Thread Information
Users Browsing this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204
