Terence's Nissan S13/1jz Swap Build
Old Mar 31, 2010 | 06:10 PM
Hybrid Motorsports's Avatar
Default Terence's Nissan S13/1jz Swap Build
Terence came to us with the goal of getting his S13 hatch going with some JZ power so here we go!!
Most unnecessary accessories were eliminated.
Rear/front sump swap
Water/hydro pump swap / While in there we'll replace the timing belt aswell.
Fuel & Clutch line modification
Hybrid Motorsports LLC.
9470 Ulmerton Rd.
Largo FL. 33773
Unit 3E
Ph. 727.753.9664
Shop Forum:
https://www.tamparacing.com/forums/hybrid-motorsports/
Old Apr 2, 2010 | 07:13 PM
Default Update
Recieve a minty fresh water pump from mister yota.
And of course we try to look out; here are the part numbers# this gets you the whole assembly when doing a hydro pump swap. hope it helps at least it will save you a trip to the dealer to verify,
-pn#16100-49847
9470 Ulmerton Rd.
Largo FL. 33773
Unit 3E
Ph. 727.753.9664
Shop Forum:
Old Apr 8, 2010 | 04:20 PM
Default Update
This section covers:
> Water pump removal
> New pump install
> Timing belt install
> Crank pulley install
> Radiator test fitment
> Crank/Water/Alt belt tensioner bracket build
> Clutch install
> Mating transmission to engine
Hydro setup completely removed, New pump on.
Got the slightly oversized radiator to fit right.
The power steering pump, ac compressor & stock serpentine belt tensioner will no longer be need so you'll need something to tension the belt.
We run this bracket on the zupra and works great when removing all, but the very essentials crank/water/alt.
We made a few extra for those of you that are going that route $35 shared_pm for more info.
So now we got the engine off of the stand, and ready to install the clutch
The W58 transmission:
Engine & Tranny mated:
9470 Ulmerton Rd.
Largo FL. 33773
Unit 3E
Ph. 727.753.9664
Shop Forum:
Old Apr 8, 2010 | 04:37 PM
shinmei2006's Avatar
looks nice
http://www.hashiriya.net
Old Apr 8, 2010 | 04:52 PM
Thanks man
9470 Ulmerton Rd.
Largo FL. 33773
Unit 3E
Ph. 727.753.9664
Shop Forum:
Old Apr 8, 2010 | 08:04 PM
cody_ettl13's Avatar
YEAH I KILL IT
good lujck justin i wish i still friends with the old crew i would come by.
<RIP-TIM>
Old Apr 9, 2010 | 06:02 AM
Thanks Man
^Feel free to stop by anytime, Hybrid Motorsports is a business and does not take part in anyones personal issues.
9470 Ulmerton Rd.
Largo FL. 33773
Unit 3E
Ph. 727.753.9664
Shop Forum:
Old Apr 9, 2010 | 06:28 PM
Default Update
So alt bracket fitted up:
Engine ready to go:
And finally in!
Now to the driveshaft shop, So we can get these mated & balanced.
9470 Ulmerton Rd.
Largo FL. 33773
Unit 3E
Ph. 727.753.9664
Shop Forum:
Old Apr 21, 2010 | 03:10 PM
Jap's Avatar
Jap
VTEC Out
Nice build ...
I'd like to see some pics of the z in the back haha
Hondata saves lives
Old Apr 21, 2010 | 06:35 PM
Thanks man, Check the Hybrid Motorsports forum for more info on the Zupra.
9470 Ulmerton Rd.
Largo FL. 33773
Unit 3E
Ph. 727.753.9664
Shop Forum:
