+ Reply to Thread
Page 1 of 2 1 2 LastLast
Results 1 to 15 of 19
  1. #1
    Registered User Hybrid Motorsports has a reputation beyond repute Hybrid Motorsports has a reputation beyond repute Hybrid Motorsports has a reputation beyond repute Hybrid Motorsports has a reputation beyond repute Hybrid Motorsports has a reputation beyond repute Hybrid Motorsports has a reputation beyond repute Hybrid Motorsports has a reputation beyond repute Hybrid Motorsports has a reputation beyond repute Hybrid Motorsports has a reputation beyond repute Hybrid Motorsports has a reputation beyond repute Hybrid Motorsports has a reputation beyond repute
    Join Date
    Jul 2008
    Posts
    342
    Feedback Score
    1jz-gte lexus sc300 swap pt. 2
    Well in part 1, We removed the engine and prepared the car for the installation of the 1jz, but before that we'll have to prepare the 1jz for the car
    So here we are with the arrival of our toyota soarer 1jz-gte inline 6, 2500cc (2.5l) twin turbocharged engine along with the r154 transmission. ( for those of us who are unfamiliar with this engine)
    First thing we'll do is extend the wiring harness, change the oil, spark plugs aged ignition coil pack clips, install new motor mounts (rubber), rear main seal, perform a compression test and make sure everything is within tolerance before installation ( while we have it out )
    this is how the engine came, it's pretty neat trick but we'll replace them
    Now that the engine is ready it's time for installation.
    It's in !!
    The car is running at this point, as you can see the wiring and the cooling system are both completed. It's now time for the charge cooling (intercooler) system which we will be addressing next.
    Now the intercooler system. ic=24x12x3 2.75" pipping.
    In this stage the intercooler pipping is tricky, there's alot of tweaking that needs too be done. My recommendation is if you can use 2.75" pipping it will make things easier. The 3" inch we used on the 2jz swap was necessary due the power levels that we wanted to achieve but was somewhat harder.
    Now we'll install the front bumper, headlights ,charge pipe etc. etc.
    Looking like factory
    A finish product!
  2. #2
    Registered User loudehhh is an unknown quantity at this point
    Join Date
    Oct 2009
    Posts
    Feedback Score
    how much do you charge for this swap with motor and everything you need. very interested in doing this swap.
  3. #3
    Join Date
    Jul 2008
    Posts
    342
    Feedback Score
    Thanks for your inquiry: pm sent.
    Hybrid Motorsports LLC.
    9470 Ulmerton Rd.
    Largo FL. 33773
    Unit 3E
    Ph. 727.753.9664
    Shop Forum:
    http://www.tamparacing.com/forums/hybrid-motorsports/
  4. #4
    Registered User acidburnvictim is an unknown quantity at this point
    Join Date
    Feb 2011
    Posts
    10
    Feedback Score
    My name is Jason and I have an SC300 that i need a 1jz swap done for. I need to get some dollar figures from you guys so that I can get my ducks in a row to get the car over too you. I have already swapped the tranny to a 5 speed however I am hearing clutch chatter and so i'm going to swap it when the engine is done. get back to me so that I can go over everything else that I need done. ready to do this now.
  5. #5
    Registered User bikeimports has a reputation beyond repute bikeimports has a reputation beyond repute bikeimports has a reputation beyond repute bikeimports has a reputation beyond repute bikeimports has a reputation beyond repute bikeimports has a reputation beyond repute bikeimports has a reputation beyond repute bikeimports has a reputation beyond repute bikeimports has a reputation beyond repute bikeimports has a reputation beyond repute bikeimports has a reputation beyond repute bikeimports's Avatar
    Join Date
    Jun 2007
    Posts
    669
    Feedback Score
    1 (100%)
    Thank you for your inquiry: Pm sent.
  6. #6
    DrLoveCoins Jared Clarke is an unknown quantity at this point
    Join Date
    Feb 2011
    Posts
    Feedback Score
    i have a question. did u guys have to do the tach and temperture modification for the guage cluster?
  7. #7
    Join Date
    Jun 2007
    Posts
    669
    Feedback Score
    1 (100%)
    Quote Originally Posted by Jared Clarke View Post
    Yes
  8. #8
    Registered User Ride_on_luck has a reputation beyond repute Ride_on_luck has a reputation beyond repute Ride_on_luck has a reputation beyond repute Ride_on_luck has a reputation beyond repute Ride_on_luck has a reputation beyond repute Ride_on_luck has a reputation beyond repute Ride_on_luck has a reputation beyond repute Ride_on_luck has a reputation beyond repute Ride_on_luck has a reputation beyond repute Ride_on_luck has a reputation beyond repute Ride_on_luck has a reputation beyond repute
    Join Date
    Oct 2009
    Posts
    254
    Feedback Score
    How much do you charge for a 2JZGTE motor and 6spd swap like this
    swap?
    How much do you charge for a 1JZGTE swap with a R154 5spd swap?
    (this is all for a 95 Automatic SC300)
  9. #9
    Join Date
    Jul 2008
    Posts
    342
    Feedback Score
    Quote Originally Posted by Ride_on_luck View Post
    swap?
    Thanks for your inquiry pmed.
    9470 Ulmerton Rd.
    Largo FL. 33773
    Unit 3E
    Ph. 727.753.9664
    Shop Forum:
  10. #10
    Registered User apache31405 is an unknown quantity at this point
    Join Date
    Jun 2011
    Posts
    14
    Feedback Score
    Hello sir, I am not new to the lexus/toyota scene. I just purchased a 1997 red sc300 auto and I would like the 1jzgtte turbo swap. I am sticking with the auto on this one I have a 95 6 speed acura legend coupe i can row gears on. How much for the swap please? I am going to buy a front clip if you think that is what I need or will I need just the engine and tranny with the ecu and ignitors. I know thats a little cheaper than the clip. I have a jdm vendor that has e-mailed me on the price of the clip. The engine tranny combo is half.
    I am in Iraq and would have my wife and son bring the car to you and have the engine and tranny shipped to you if we decide to go with that. Also during the process I would like for you to take pics for me please. I wont be back until Feb or March of next year. Your sight is informative and I hope your reputation precedes you. I am an Apache Helo mechanic and have been working on Toyo/Lexus since the 80's. I will talk with you soon.
    Eddie J.
  11. #11
    Join Date
    Jul 2008
    Posts
    342
    Feedback Score
    pmed thank you:
    9470 Ulmerton Rd.
    Largo FL. 33773
    Unit 3E
    Ph. 727.753.9664
    Shop Forum:
  12. #12
    Join Date
    Jun 2011
    Posts
    14
    Feedback Score
    Didnt get the pm
    Hello sir, did not get the pm on the reply on the price of the sc300 1j swap. My e-mail address is apache31405@yahoo.com you can reach me there with the details. Thanks.
  13. #13
    Join Date
    Jul 2008
    Posts
    342
    Feedback Score
    Resent thank you.
    9470 Ulmerton Rd.
    Largo FL. 33773
    Unit 3E
    Ph. 727.753.9664
    Shop Forum:
  14. #14
    Registered User wickedx83 has a reputation beyond repute wickedx83 has a reputation beyond repute wickedx83 has a reputation beyond repute wickedx83 has a reputation beyond repute wickedx83 has a reputation beyond repute wickedx83 has a reputation beyond repute wickedx83 has a reputation beyond repute wickedx83 has a reputation beyond repute wickedx83 has a reputation beyond repute wickedx83 has a reputation beyond repute wickedx83 has a reputation beyond repute
    Join Date
    Mar 2010
    Location
    Tampa
    Posts
    556
    Feedback Score
    3 (100%)
    can you send me a quote on a 1jz 5speed swap. I have a sc300 auto.
  15. #15
    Join Date
    Jul 2008
    Posts
    342
    Feedback Score
    Thank you for your inquiry; PM Sent
    9470 Ulmerton Rd.
    Largo FL. 33773
    Unit 3E
    Ph. 727.753.9664
    Shop Forum:
Thread Information
Users Browsing this Thread
Posting Permissions
  • You may not post replies
  • You may not edit your posts
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204
