setting the timing on a 3.0 ranger.
Old 11-06-2007, 01:23 PM
BillionClub Member BISHES
topher469's Avatar
Exclamation setting the timing on a 3.0 ranger.
Ok this damn thing has pissed me off. 93 Ranger 3.0 Roommate had to replace head gaskets and he put it all back together, but failed to mark distributor. So after about an hour cleaning rust off the balancer I found the timing marks. Set to TDC Fired it up and it ran like shit, shut off and checked the firing order. Its good but the rotor is messed up. Putting new rotor and plugs being they are all fouled.
Ok so the question I have is who knows the corrects timing on this? I have checked online and I am not finding a firm answer. Couple say 10BTDC and others are 14BTDC. Any help would be great thanks again all!
Originally Posted by DrDirt
You also make a foolhardy leap of faith in assuming that the government can execute a program properly when they can't even execute terrorists properly!!!
Old 11-06-2007, 02:09 PM
bluebullitt01's Avatar
my ford service information DVD only goes back to 96' so here are the specs for a 96 ranger 3.0L
SPECIFICATIONS
FIRING ORDER AND IGNITION TIMING
Spark Plug Type AWSF-32P
Spark Plug Gap 1.07-1.17mm (0.042-0.046 Inch)
Ignition Timing 10° ± 2° BTDC
Firing Order 1-4-2-5-3-6
Old 11-06-2007, 02:42 PM
topher469's Avatar
SPECIFICATIONS
Thats great! Thank you. Rep fo you
