need help
Old May 16, 2005 | 08:25 AM
stock05skittle's Avatar
just a neon
Default need help
I Went Out And Bought All That Shit Too Boost Leak Test The Car And Tried It And The Fuckin Blow Me Off Valve Just Fuckin Leaks And I Cant Find The Damn Leaks This Shit Is Pissing Me Off. WHAT DO I NEED TO DO TOO LEAK TEST IT
slow ass neon
Old May 16, 2005 | 12:33 PM
Josiah's Avatar
Peon on steroids!
hook an air compressor to your hot side IC piping and pressurize it, then spray all the joints with water, bubbling will indicate a leak
Old May 16, 2005 | 01:22 PM
cali's Avatar
Skittle on crack!
um...what BOV do you have? What other mods do you have?
You can quit watching me now....
Old May 16, 2005 | 02:12 PM
Josiah's Avatar
Peon on steroids!
dont automatically assume its the BOV, while it very well could be and probably is, dont overlook such little things as a coupler that has not been tightened back down properly
Old May 16, 2005 | 04:20 PM
just a neon
Stock Bov And I Know Thats It But There Is Acouple More Leaks Im Sure .i Have S-1,ported I/m , 60mm T/b,agp W/g,255 Fuel Pump,afc,k-n Intake,3in D/p,cca F/m,75 Wet Shot,spiking 20psi Falls To 14psi
slow ass neon
Old May 16, 2005 | 07:16 PM
ReDKeNSRT4's Avatar
That thing got a HEMI???
get rid of the stock bov... its the wga why ur boost is falling
Srt8 Magnum
Tires Plus
Plant City
754-2747
Old May 17, 2005 | 01:19 PM
riven's Avatar
Quit spreading misinformation idiot. The stock bov doesnt leak boost, thats the blue plate.
2003 Solar Yellow SRT-4
1994 RT/TT - The Tank.
Old May 17, 2005 | 01:23 PM
cali's Avatar
Skittle on crack!
Should follow your own advice, the blue plate doesnt leak either. Unless of course you steal pressure from the blue line for a MBC.
Old May 17, 2005 | 01:26 PM
riven's Avatar
no, douche mongrel, it still leaks even under different vacum source. Wanna place a bet with sonny?
Old May 17, 2005 | 03:23 PM
cali's Avatar
Skittle on crack!
haha...you are as cocky as they say.
Of course if you hook it up to a vacuum source it will leak....the Stoc BOV/Mopar BOV is controlled via a solenoid.
It is pressurized form the front when under boost,thus sealing it.
When the throttle is closed, the solenoid removes the pressue form the front and applies a vacuum. As a result the pressue BEHIND the BOV pushes out and...psh!!!!!!!!.
but you know this right?
