Specialty Products Releases 350Z & G35 Front Upper Control Arms
Old 03-21-2011, 07:05 PM
Electromotive Tuner
OB1 JZA70's Avatar
Default Specialty Products Releases 350Z & G35 Front Upper Control Arms
Alignment Components Control Arm; Front Camber/Caster
Part #: 72125
SPC Performance's 350Z & G35 kit was the first on the market to provide a substantial amount of positive camber change. Additionally, its patented design makes it the only arm on the market that provides adjustable caster. There is more than enough camber and caster change to correct cars that have been lowered, or for vehicles used in drifting. Installed by itself, the control arm provides ±1.5° of camber and ±1° of caster. If more camber is required a +2° fixed shim will provide up to +3.5° of positive camber. With this remove and replace arm, techs can fine tune both camber and caster to save tires and improve handling along with tire to surface contact. The kit includes everything you need, including the ABS sensor bracket, shims, and arms for both sides of the vehicle.
New Design Features & Benefits:
More than 20% reduction in unsprung weight
Imporved clearance for tight wheel wells & soft springs
Arm is formed from a single piece of steel rather than welded assemblies
www.BivcoPerformance.com
Specialize parts, Tuning and Tinting Specialist
813-380-7027
BlindSniper
12-07-2009 01:08 AM
robofunc
For Sale/WTB Honda & Acura
04-09-2009 05:35 PM
96hatchEK
12-18-2007 03:25 PM
power2weight
03-01-2006 07:56 PM
Quick Reply: Specialty Products Releases 350Z & G35 Front Upper Control Arms
