videoed it and we noticed in slow mow that the rear spark was erratic
Old 01-19-2017, 03:24 AM
Default videoed it and we noticed in slow mow that the rear spark was erratic
Lee
I have a 2008 1200 sportser with a first stage screaming eagle kit my rear cyl started missing and I tried every thing to fix it I have changed plugs,wiring, injectors,coil and tried inj cleaner performed resistance test on wiring and checked wiring for any damage the battery is good we even checked the spark and we videoed it and we noticed in slow mow that the rear spark was erratic it has been to the Harley shop and on the dyno and they can`t figure it out can any body please help I`m going nut`s here
Old 01-19-2017, 03:25 AM
Customer Service
Hi, Lee. If the coil is determined to be good and you are certain that it is only the rear cylinder; the ECM may be bad.
If you haven’t already, check for diagnostic trouble codes.
07-03-2021 03:43 PM
03-17-2019 02:23 AM
The TRuck Forum
07-17-2018 02:50 AM
Quick Reply: videoed it and we noticed in slow mow that the rear spark was erratic
