clutch question?
Old Jun 27, 2003 | 09:50 AM
Levi's Avatar
Default clutch question?
Can't shift into gears now, while rolling, I have to stop the car, shut it off put into gear and drive in that gear only.
The clutch seems to work fine, its the engagement of it is the problem I think.
Is there an adjustment for the clutch cable?
what does that shit inside the clutch pedal do? being I can't see it.
Help..........
custom parts is our perfection.
Old Jun 27, 2003 | 11:25 AM
340 Dak's Avatar
I'm rich, biotch!
hows it not going in? its grinding the gears? or you physically cant push it into gear no matter how hard you push
i thing they have auto adjusting cam thing on the top of the pedel. Never played with it though. check the FSM or td.com
Old Jun 27, 2003 | 02:07 PM
Levi's Avatar
heres the deal, pull the pedal up and this releases the arm, and thus adjusts the cable..its seems simple, my problem is the pedal has 2 set of teeth one on the piece holding the cable, and the other holding arm for adjustment. these teeth are slipping, once I adjust it. someone put a piece of wood in it to make the spring stronger, but I can't seem to make that work..
maybe the cable has got longer?
Hold the clutch to the floor start it and instantly the car moves. while the pedal is to the floor.
Old Jun 27, 2003 | 06:03 PM
rangcrx's Avatar
engine building &best
sound slike you need a new clutch cable thats all
i love AUTOZONE
Old Jun 27, 2003 | 06:50 PM
Levi's Avatar
The car is a 1987 Charger GLH-S #0867
Levi's Avatar
So the cable became too long?
The car was working today with the wood piece jammed in, now that it came loose ,I have no clutch engagement.
Old Jun 27, 2003 | 07:01 PM
340 Dak's Avatar
I'm rich, biotch!
did it just start this? you were driving it before with the fuel problems and stuff...
Old Jun 28, 2003 | 03:24 AM
Levi's Avatar
Yes this started 100% yesterday afternoon.
The car runs great, I had no problem smokin this GS vette. @ half throttle....yesterday morning.
where can a cable be gotten @? A new one?
Old Jun 28, 2003 | 08:36 AM
340 Dak's Avatar
I'm rich, biotch!
dealership im sure!
also did you check where it mounts to the arm on the outside of the tranny? That rubber thing and little metal slide are kinda hokey
Old Jun 30, 2003 | 04:26 AM
Levi's Avatar
I blew the pressure plate apart, with only 800 miles on a stage 2 setup...I will let you guys know after I drop the trans and see..
