Boost & JE Pistons
Okay i have JE 8:1 pistons in my motor now, which is fine but i'm told by a couple people that JE and boost don't work well together because they tend to get hot spots more frequently then other any one else heard anything??? also need a tampa/st.petersburg shop to do pistons rering any suggestions besides the ovious LHT/Secret Services??
JE's not good on boost? I dont know who you have been speaking to but I would stop talking to that person. JE is one of the better manufactures on the market today and Forged pistons are well suited for the job of boost. If you need help building the motor I work at a 39,000sq foot engine builder in Inverness, Fl not too far from you and you can ship real easy if you didnt want to take the drive. Give me a call...
Alex Costa
Precision Machined Engines
1-800-665-0405
Alex Costa
1-800-665-0405
see thats what i thought, but my pistons are less then 600 miles old and already under mid boost 10-15lbs it will start smoking until i downshift and let off the boost.... i know it not the valves because i just had them redone less then 3 months ago when i bought all stainless and titanium upper end parts any ideas
Guest
Posts: n/a
Oil rings have gone bad.
My compression rings from JE never seated properly. So im stuck with boost leaking into my crankcase.... yay.
JE does not have my vote as far as high quality.
600 miles and 15psi is well... not something I would run until they're broken in.
What is your setup? Your turbo seals could also be the issue.
accord 97 w/h22a 94'
starting from top to bottom:
ferra titanium locaters/retainers Full 3/8 full system (Stainless Line)
stainless one piece valves Aeromotive Sunami Fuel Pump
stainless dual valve springs Aeromotive 1:1 Regulator
crower stage 2 cams Aeromotive 10/100 Micron Filters
JE 8:1 forged pistons Vortec FMU 12:1
crower forged rods RC 440 Injectors
moroso 5 qrt. pan and filler AEM Fuel Rail
garrett TO4E (o-trim) turbo Fast Acting 02 Senors
3" exhaust full (no-cats) and soon hondata ECU
2 1/2" turbo piping
Full Innercooler (28"x8"x3")
Also Thursday will be going to Secret Services again to have everything checked over and to get some baseling dynos....
2 1/2" turbo piping
Sounds like a pretty good setup.
Sorry to hear that its smoking on you though. Assuming nothing is majorly fucked up I would also be guessing its improperly seated rings or turbo seals.
There is also the possibility that it may not be oil smoke if your fuel setup may be going crazy rich under boost which could make your engine appear to be smoking.
well i know for a fact its oil because the smoke is white...but i just had the turbo fully rebuilt (all bearings, seals and shaft) and balanced... so i think its got to be the pistons...
