Need some HELP!!!!!!
so my water pump was bad so i changed it and put on a new timing belt yesterday, i lined all the timing marks and everything looked good. when i started it, it runs rough, the idle is very bad and i can feel a vibration in the car now, do any of you know what this could be from? Thanks kyle
Something has been over looked that's for sure. If it ran fine before you took it apart and now it does not its something that was done incorrect. Running rough suggests timing marks aren't right or its missing for some reason like crank sensor got hit or something. Check compression, verify a thing or two... Take it back apart inspect all the marks its easy to be a tooth off. Make sure everythings right,, if you have balance shafts check all those marks. Mistakes are made sometimes, odds are its a easy fix you just have to get dirty again.
Check you timing again. The exhaust cam is probably off one tooth.
Timing is off. Check plugs.
PUREBRED PERFORMANCE
Fabrication & Tuning Services
813-451-7547 or 813-712-0202
Www.PPETUNED.com <~~ WEBSITE
Curious on honda/acura Ecu Chipping and dyno tuning? Call or visit the website above. Hondata/Neptune/Ectune/Crome Pro. Tuning available for most other systems and platforms as well. DYNOJET
I say timing...
ya i rotated the motor 6+ times to make sure the oil pump was still in line, maybe the bs is off, if the bs was out of time would that make it mess up? and if i delete it there wont be a belt so is timing for that still a issue?
