1987 Crown Vic
Old May 24, 2011 | 08:29 PM
Hurstmeister's Avatar
Default 1987 Crown Vic
Friend of my father inlaw has one and wants me to swap it to carb and put a cam in it.
Simple enough,.. how ever I have an E-303 cam I want to use.
87 302 Crown Vic used 1-5-4-2-6-3-7-8 firing order. E-303 is an HO cam that uses the 351/HO 302 firing order of 1-3-7-2-6-5-4-8.
Can I simply use the E-303 and wire the distributor as an HO? I dont see why it wouldnt work, but this is a grey area for me because I've never done it, so I am asking anyone else who has or tried. Will the HO cam work in a non HO motor?
Edit:
Also forgot to mention. 87 LTD Crown Vic have flat tops with no valve reliefs. Basically same as an 86 HO Mustang would have. So assuming we're talking about an 86, whats the max lift cam they will take before PTV issues? E-303 IIRC is .498 lift with 1.6 rockers.
Hurst
Originally Posted by Tiffiny
"We all heart the Hurst"
Old May 25, 2011 | 03:57 AM
$hawn's Avatar
lives in a glass house
yes swap the cam and use the ho firing order, its that simple. p/v *should* be ok with the stock E6 heads.
Originally Posted by cochese
Focus on getting that piece shit down the track, stop posting stories.
Old May 25, 2011 | 04:43 PM
Thanks man. Not sure how well the E-303 will work with those shitty heads but he's an older guy and just wants something that will give the motor a little rumpity rump,.. nothing too aggressive. I figured the E-303 would be perfect. Just going to put an RPM Performer on there with a 600 Holley, do a 1 wire HEI dizzy, Holley blue pump and the E-303 and he should be good to go.
He inherited the car from his mother. It has just over 40k original miles on it. It smells musty from sitting for so long. The EFI works but its breaking up when he gets on it. Its sat for so many years that I dont even want to begin to chase down where the problem is. I dont have the time for it even if I wanted to. He wants a carb on there, and that is something I have a bit of experience with. So if you pull up next to a Crown Vic wagon with wood grain panels and hear a rumpity rump coming from the flow masters and see a silver haired cocky senior behind the wheel,.. there ya go.
Hurst
Old May 30, 2011 | 08:02 PM
Duceanahalf's Avatar
is doing your girlfriend
you might wanna check because i dont recall the panthers getting rollers lifters, especially in 86
Old May 30, 2011 | 10:43 PM
I'll find out when I pull the EFI off. Flat Tappet cams are cheap if I have to buy one. I can get him one with near identical specs just might be on a 112 instead of a 110 which should be better for that motor anyway.
Old May 31, 2011 | 10:45 PM
Not sure where you got your info from but I pulled a lifter out today. Its a roller block. Its getting the E-303 I have.
From first appearance it looked just like a 5.0 EFI engine with the upper intake on backwards.
Hurst
Old Jun 1, 2011 | 06:59 PM
Hurst
I never said it wasnt, i just said that i didnt remember them getting the roller lifters then.
effDOHC
Oct 28, 2007 04:48 PM
ThaiRacer
Apr 14, 2006 03:52 PM
Matt the Pilot
Aug 17, 2005 08:18 PM
