96 civic hatchie drum brakes converted to disc brakes ?Quest.
Old May 19, 2011 | 03:14 PM
CreAsiaNDoriEj6's Avatar
Default 96 civic hatchie drum brakes converted to disc brakes ?Quest.
ok, i picked up a set of rear disc brake assambly off a 96 teg, to do drums to disc on my hatch. i disassembled all of it to start the process of sand blast, powder coat, replace hub bearings, bushings, rotors, and pads. but i noticed there was a abs sensor (i think) on the back of the assembly... but i guess it was clipped. but i have the e-brake cable thou... but anyhow my ? is do i need that abs sensor thingy majiggy????LOL<~~~~~~~~~~ idk can some1 help me on this.................and what would be the conz if i dont have it.......????? thankz for looking
Old May 19, 2011 | 08:48 PM
MikeyL513's Avatar
BOOSTIN
Wheel speed sensor for abs. Your car does not have abs therefor you dont need to do anything with it.
Old May 20, 2011 | 03:19 PM
flatrex's Avatar
crx hatch sedan
I believe you will need a different proportioning valve also
Old May 20, 2011 | 03:21 PM
boca's Avatar
Old School TR member
yes he will!...50/50 i believe....go to hondatech for a how to write up
Originally Posted by Liquid
Haha we started it.. we finish it.
Old May 20, 2011 | 04:06 PM
whats a proportion valve and purpose??? where can i get one of those?? ebay idk....?? let me kno what i should look for..... thanks for the help ppls......
Old May 20, 2011 | 05:09 PM
boca's Avatar
Go to hondatech!!!!!....
Old May 22, 2011 | 09:52 AM
flatrex's Avatar
crx hatch sedan
Yeah I'm not sure which one he will need. I'm using a 40/40 on my hatch, but I have heard the ek brakes end up sucking if you convert the rear with out changing the proportioning valve.
The proportioning valve basically supplies different pressures for the front and rear brake systems.
Old May 22, 2011 | 12:59 PM
MikeyL513's Avatar
BOOSTIN
^yep. And yea i think most people use a 40/40.
Old May 22, 2011 | 01:26 PM
boca's Avatar
yea its 40/40
Old May 22, 2011 | 01:57 PM
flatrex's Avatar
crx hatch sedan
If you look on hondatech all you will find is people telling other people they aren't using the correct one, pr if you make a thread about it some douche will get his panties in a bunch and tell you to use the search feature instead of just helping you. Lol
Hondatechs shit don't stink
