Is it my thermostat?
Old May 3, 2011 | 06:48 AM
Clifford's Avatar
weezin the juice
Default Is it my thermostat?
I've got a 02 1.8t GTI and I was driving on the highway the other day and noticed something. My temp gauge started climbing a little so I threw the heat on and it went down to 190 again. As I got closer to work I started to play with it to see if I could determine what caused the problem, I turned the A/C on and the temp gauge started to climb again so I threw the heat back on, nothing was leaking or anything either so could it be the thermostat? If not, what could it be because I need to get this fixed asap. Thanks guys..
Old May 3, 2011 | 07:10 AM
G-Magoo's Avatar
July - Ride of the Month
I know it sounds trivial, but is there the right amount of coolant in the system? How many miles on the car?
I love haters..
Originally Posted by VR6exxy
I love your brutal honesty. It makes my day
Build thread
Old May 3, 2011 | 08:46 AM
bettaberettaboy's Avatar
That Fat Guy
Without any other information Id say Thermostat
Old May 3, 2011 | 01:59 PM
Clifford's Avatar
weezin the juice
What other information are you looking for?
101k on the clock and plenty of coolant running through the system. Just had a line bust and had to replace it so I had to fill up the system with fresh coolant..
Old May 4, 2011 | 04:12 AM
seven's Avatar
waterpump
___________________________
Blue Collar Motor Sports
SCCA ITC New Beetle
sponsors:
urotuning.com
Old May 4, 2011 | 06:43 AM
G-Magoo's Avatar
has the timing belt/waterpump been changed ever?
If you really want to eliminate the thermostat, take it out and put it in boiling water to confirm it opens.
I love haters..
Build thread
Old May 4, 2011 | 04:52 PM
Clifford's Avatar
weezin the juice
Ok, so my fan isn't working for some reason, how can I go about figuring out if it is the relay or the actual fan motor?
I can drive for a while before the actual temperature goes up, about 5-7miles, because the fan seems to start on initial startup, but not every time. I've just noticed that I can go for a little bit and have the temp stay normal, then it seems to jump around 190 for a bit, goes up and down very slightly opposed to staying on 190. So how can I figure out if it is the relay or the motor in for the fan?
Old May 4, 2011 | 09:25 PM
mrnicejetta's Avatar
farfromügen
you can take a couple of wires and hook the fan directly to the battery. Doesn't matter which terminal (if it's 2 pin), if its reversed the fan will just spin the opposite direction. If it works, it works. If it's 3 pin, I'd imagine one pin for a/c source, one for coolant temp source, and the ground.
Der schnellste mann im langsamsten auto
Old May 6, 2011 | 08:16 AM
Justin@UroTuning's Avatar
If the fan works sometimes i'd lean on it being the fan module or a flaky fan switch. Either way if you figure it let me know and i can hook you up on the parts.
Old May 6, 2011 | 12:25 PM
seven's Avatar
I've got both fans complete if you end up needing 'em.
SCCA ITC New Beetle
sponsors:
urotuning.com
