really need help with my 5.slow
Old Mar 8, 2011 | 02:06 PM
Superwes98's Avatar
Default really need help with my 5.slow
ok again, i have 92 GT with minor bolt ons. intake, 65mm T/B, msd 6A(which is not connected), msd coil, headers, full exhaust, pulleys, CAI, and 73mm MAF
recently my cars ecu went bad and i replaced it with a A9P and since then iv had this horrible surge (sometimes buck) while cruising, slowly accelling and at idle.
today i replaced the MAF, TPS and set it to .98, IAC, ACT, CTS, set timing to 10 degrees, set FPR to 40psi, did a base idle reset and sprayed carb cleaner everywhere with no changes. after that it now bucks and will slowly accelling and cruising
when i unplug the maf it will rev up and run smooth for a minute or two and then start running bad again.
if anyone can help, i could really use it. this car has not driven right in almost a year.
Old Mar 8, 2011 | 03:07 PM
Hurstmeister's Avatar
How are the O2 sensors?
Have you done the Salt n Pepper shaker mod yet?
Ford had a TSB out on the 87 - 92 Salt and Pepper shakers. Mid year 92 and the 93 models were corrected. But from what I've read the contacts inside dont always meet properly and when they age it gets worse. The mod is to pull them apart, clean them up, tweak the top of each pin so that it swells the end to make it larger. Then put some dielectric grease in it and put it back together. The symptoms are erratic idle and surging when they go bad.
When you reset the idle,.. did you do it with the IAC unplugged and set the TB screw as low as it would go before the car stalled out?
I just went through some of this with my son's car. I'm no expert with EFI. I want to be up front with that. I'm just going by what I've read and the results that I got by tweaking on it. I finally got the car to where it would idle and run good. Still wasnt perfect. But it was much better then when I first started.
Also,.. just out of curiosity.
Can you get a fuel pressure gauge and see if the fuel pressure is dropping at all?
Because it could be possible the pump could on its way out,.. or the pickup tube or line could have a clog or the filter may have a clog.
Also,.. what condition are your plugs in? When I saw your car last you and your buddy's cars both seemed to have a good bit of blow by in them. Fouled plugs can create different problems as well.
Pull 3 or 4 plugs and see how they are doing. And I know this may sound dumb,.. but have you double and triple checked for vacuum leaks? Even the most minute leak can create problems. Also,.. any kind of exhaust leak before the O2's will send a bank lean code to the computer causing the motor to run pig rich as it tries to correct a problem that isnt there. I went through this with my 96 and couldnt understand wtf was going on. Then found a small tick where the gasket was leaking on cylinder #8. It was so easy to over look it because the exhaust itself was pretty loud and the tick was very minor. Replaced the exhaust gaskets and viola. No more bank lean code.
Just some ideas to look into.
This is why I honestly dont like EFI. Its nice when its working right. But you'll end up searching for hours, days or weeks even trying to figure out a problem. And the thing with EFI,.. symptoms arent always what they appear. Like the bank lean code. Motor wasnt lean,.. it was pig rich. Plugs dont lie. Yet thats the code I had. And a simple exhaust gasket fixed the problem. With a Carb its right there in front of you,.. spark and fuel. Very simple to diagnose and correct. Not saying one or the other is better. Just my reasoning to prefer a carb over EFI when it comes to modified engines.
Hurst
Originally Posted by Tiffiny
"We all heart the Hurst"
Old Mar 8, 2011 | 06:11 PM
Superwes98's Avatar
i just put new new plugs and wires in. i got a new set of 9mm ford racing wires at NMRA and motorsport copper plugs. lol
and when i did the base idle reset i didnt go as far as i could. i was under the impression to set it where i want my idle to be.
also i did do the salt ans pepper thing a little while back when i was tryin to find my previous problem (when ecu was bad).
and its cool, u older guys know more than me thats why i try to hang around u guys and take your advice. and realy appreciate your help
Old Mar 8, 2011 | 06:36 PM
Tiffiny's Avatar
I can fix your bullshit
I would reset timing......did you unplug the spout connector when you set it.....
Old Mar 8, 2011 | 06:39 PM
Superwes98's Avatar
yes sir
Old Mar 8, 2011 | 09:04 PM
SpankReasY's Avatar
While you are figuring that out. Throw a set of 3.73s or 4.10s.
The best bang for the buck. Honestly!
When in doubt...When in fear...Just drop a gear and Disappear
Old Mar 8, 2011 | 10:04 PM
GNs-r-slow's Avatar
Bondsman
If you pulled the spout and set timing at 10 degrees, its too low
Old Mar 9, 2011 | 04:23 AM
Superwes98's Avatar
i thought thats where its suppose to be, 10 degress with spout out
and i have a set of 3:55's, i just dont have the tool
Old Mar 9, 2011 | 04:38 AM
herrcomestrouble's Avatar
What does the car do under wot?...... how old is cap/rotor?...... if changed recently, was there any moisture in the cap?. What do the new plugs look like, rich/lean?......
Sn95' Tripple Black Cobra
Mods:Heads/Cam/Intake/Exhaust...just your typical stock mustang...
Old Mar 9, 2011 | 04:57 AM
racingrick's Avatar
POTENTIALLY FAST
agree on the 10degrees timing not enuff! also, probably a dumb question, but have you looked to make sure you don't ahve a lot of carbon buildup on your throttle body? and how often are you checking your plugs?
