DX motor HELP
Old Sep 11, 2002 | 08:02 PM
Purple004's Avatar
Isn't life peachy
Default DX motor HELP
I baught a DX motor. (i think it came from a 89 hatch)
I think they put the multi port injection from my HF on the DX motor and i think im useing the same HF ecu from the old motor.........My questin is.... why do i get 18MPG
That really sucks ass...... it really bugs me cause im a Pizza delivery guy and i got to fill up like every day almost
..........Any Help please
.......Thanx
Old Sep 11, 2002 | 09:00 PM
darkjungle565's Avatar
look at my ball!
i have a dx ecu if you think thats the problem.
aim - sickazzjungle -
Old Sep 12, 2002 | 09:32 AM
Purple004's Avatar
Isn't life peachy
Default .
did it come from dual port injection motor??
and what car did it come from.
Old Sep 12, 2002 | 09:54 AM
i-h8mytruck's Avatar
GONZO SHAPED MEMBER
As long as it's a 4th gen DX ECU it is dual port.
Old Sep 12, 2002 | 02:27 PM
Sneakin Deacon's Avatar
PSSHHH x2
should he use an si ecu, cause im not sure if an HF would be able to give it enough gas, had the opposite setup on a friends car, hf motor with si ecu and it wouldnt go over 65 cause it would get too much gas, but what ecu are you using now?
El Pendejo Loco
2002 Suzuki Hayabusa
1507 "dry" block
Brocks megaphone
Spencercycle 10" swingarm
MPS auto shifter
Hays convertible clutch
Yea, that about sums it up...
Old Sep 13, 2002 | 08:13 PM
Purple004's Avatar
Isn't life peachy
Default hf
Im useing my HF ecu but i get 18mpg ...... it really sucks
what should i do????
Old Sep 13, 2002 | 11:23 PM
99B16Si's Avatar
that sucks, even my car gets better gas mileage than that. pull out your plugs. at 18mpg on an hf they should black. maybe your odometer is fucked up.
Old Sep 14, 2002 | 05:54 AM
PSSHHH x2
does it smoke? if it does what color? your rings might be bad... what tranny do you have on it? the dx or the hf? part of the HF's amazing 35+ mpg is those amazingly long gears
all i can really say is do what b16 said to, check your plugs, if they look fine then i dont know what to tell you, is your check engine light on or anything?
also, you say you THINK its mpfi? im not sure if an hf ecu would run with a dpfi manifold but pop ur hood, and look to the back of the engine on top, is your intake manifold like a kinda black circle with PGM-FI writtin on top? or is it a metal manifold and 4 runners coming from underneath to the engine?
El Pendejo Loco
1507 "dry" block
Brocks megaphone
MPS auto shifter
Old Sep 14, 2002 | 06:53 AM
Moriarty's Avatar
Yes its a multi port injection manifold on a DX motor........... and yes he is runing a HF ecu
=========|Chris|=========
Moriarty's Avatar
Whats up ?????18mpg
