No Fuel to Injectors..??...Help(?)
Old Dec 16, 2010 | 07:07 PM
I-NEED-VTEC's Avatar
I have NO vtec!!!
Default No Fuel to Injectors..??...Help(?)
Trying to figure out why I'm not getting fuel Passed my Injectors..Any ideas?
I have fuel pressure/spark...the main relay is good...idk..
Fighting for peace is like
screwing for virginity.
TR "Old Skool EF" Member #097
http://www.myspace.com/keith1201
Old Dec 17, 2010 | 01:37 PM
JoKiE crx4294's Avatar
popeye built!
You need gas in the tank....
Can't spell strength without tren
AAS...It's whats for dinner
Old Dec 17, 2010 | 07:23 PM
I have NO vtec!!!
LOL...
Thanks for the help.. Captain Obvious..LOL.
There IS gas in the tank, btw..
Old Dec 17, 2010 | 07:42 PM
Red2GDSM's Avatar
In the making...
Kink in the fuel line, bad filter, any CELs?
Originally Posted by solsi2000
does this magical box come with a pussy magnet?
Originally Posted by NISSAN
need to fill ur vtec fluid back up, thats why, its located in the back of the block, the little black box.
^^Lmao this shit was just funny
Old Dec 18, 2010 | 12:04 AM
I have NO vtec!!!
I'll check and see if I have any codes.
I'm getting fuel to the rail, just not past the injectors...I took off the rail to see if fuel would come out of them after priming the pump, but nothing did. One of the injectors "popped" off the rail cause of the pressure, and shot gas out so I know the Filter/pump/lines are clear...Could the injectors be bad?
I'll get the codes in the morning..
Thanks.
Old Dec 18, 2010 | 02:40 AM
BoostedRacerDad's Avatar
Pops
You didnt say what motor or Ecu but here is generic print. With key on, test for 12vdc on the Yel/Blk wire. The Ecu provides the ground at different pinount locations for each injector.
Jdm b18c R LSD CRX si
TR "Old Skool EF" Member #96
JoKie TuNinG
RANGCRX BUILT TYPE R
StricKlyMT
727-510-6301
Old Dec 18, 2010 | 07:57 AM
I have NO vtec!!!
^^Sorry about that, it's a D16Y7 with a P2E Ecu....
Old Dec 18, 2010 | 11:52 AM
FoxHondaRider's Avatar
Registered Hater
Had the same problem with the injectors not squirting. It was at the thermostat ground that I found the problem. For some reason the location it was at before wasnt grounding properly. Moved it to another spot and bam the car is fine.
Originally Posted by *JamReX*
The only thing worse than fucking ricers, VW .... who think theyre style is somehow supreme to all others.
Honda builds go from yay to gay in the matter of a K.
Old Dec 18, 2010 | 02:44 PM
I have NO vtec!!!
No shit?...LOL...I guess I'm moving mine then...hahaha, that'd be nice if it was something that simple...
Thanks, and rep.
Old Dec 19, 2010 | 06:46 AM
MotoX's Avatar
Master Tech
Didnt you post up before with a dizzy problem? If moving the ground doesnt work and you dont have injector pulse, it will be a hall effect type sensor in the dizzy causing the issue.
