Wiring FAN to switch
Old Dec 13, 2010 | 09:41 AM
efkidd525's Avatar
I do what I do
Default Wiring FAN to switch
how do i go about doing this?
i connect the driver side fan to the battery and it turned on just fine. but will not turn on when car gets hotter.
also my ac fan doesnt work either. can and/or should i wire both fans to 1 switch?
TR "Old Skool EF" Member #179
Old Dec 13, 2010 | 09:45 AM
HogHead's Avatar
buy switch, hook one wire from fan plug to a ground, one to the switch, then the other from the switch to your battery.
cut it on, if the fan blows the wrong way, switch the ground and the power wires coming off of the fan
or instead of putting it on a switch, just run one wire to ground and one wire to something that comes on when the car comes on in the fuse box under the dash.... it will stay on the whole time the ignition is on but you wont ever have to worry about forgetting to turn your fan on.
Old Dec 13, 2010 | 09:56 AM
HogHead's Avatar
you can see the it in this pic... I moved the ground down to the frame so you couldn't see it and put a black wire instead of the long yellow one later:
Old Dec 13, 2010 | 01:28 PM
Red2GDSM's Avatar
In the making...
If your fan doesnt come on then you prob have a bad temp sensor. What I suggest doing (and I have done this with every civic I have had) is unplug the little wiring harness that clips into your temp sensor (its on the thermostat) then get a wire strip both ends and stick each end in each side of the harness. That creates a loop that makes your fan turn on when you start the car, and will stay running the whole time you are driving. I've noticed that it does keep your motor considerably cooler.. if you want a picture LMK i'll post one up
Originally Posted by solsi2000
does this magical box come with a pussy magnet?
Originally Posted by NISSAN
need to fill ur vtec fluid back up, thats why, its located in the back of the block, the little black box.
^^Lmao this shit was just funny
Old Dec 13, 2010 | 01:31 PM
integra's Avatar
90% grind 10% sleep
Dont wire to switch...thats rigged...
Do the work and find the problem. Dont half ass shit.
Honda Valve Adjustments 50$
I TUNE KPRO AND S300
I DO NOT WORK FOR FREE
Originally Posted by THE_ONE
Old Dec 13, 2010 | 05:13 PM
BoostedRacerDad's Avatar
Pops
^+1 Start Here
Check all the fuses in this print. Then with ignition on jump the fan switch which is closest to firewall use a piece of wire. Fan should come on. If it does replace fan switch.
Condenser fan check the relay after you try running 12vdc to make sure fan even works.
Jdm b18c R LSD CRX si
TR "Old Skool EF" Member #96
JoKie TuNinG
RANGCRX BUILT TYPE R
StricKlyMT
727-510-6301
Old Dec 13, 2010 | 09:28 PM
DRMORTY's Avatar
Once Ruled The World .l..
^+1
TR
"Old Skool EF & DA Crews" Member #46
TR "Wagovan Club" Member #1
Old Dec 14, 2010 | 12:59 PM
KJ's Avatar
KJ
bored at work
First check the fuse. Then test the fan motor by just running some temp wires to the battery. Find the switch at the thermostat housing or back of the block if it is an older obd0 motor. connect those wires together and see if the fan comes on. If it does replace the switch. If it doesn't find the relay and swap that with a known good from a friends car. If that doesnt work then start tracing wires.
Old Dec 14, 2010 | 06:24 PM
chi town brat's Avatar
! Ne shab'rud'ni !
^ +1 for KJ
i found out on mine it was the fan relay.
Old Dec 19, 2010 | 01:58 PM
eightwun3zfynest's Avatar
sleeper
just remove the cooling fan relay and jump it with a wire its cleaner and defeats all that wiring,
