EF Speedo Prob
Old Oct 26, 2010 | 11:03 AM
Blackd_out's Avatar
Post EF Speedo Prob
I recently put in the effort to get my speedo in my EF to work so I bought a cable vss from ugly86integra (great seller btw). Installed it easy and connected my cable to the cluster and sensor and still nothing. Am I missing something?
I was thinking cable, but how do I tell? ..and if its not that then its the cluster correct?
This is my first EF so any help is appreciated
zoom zoom
Old Oct 26, 2010 | 03:58 PM
flatrex's Avatar
crx hatch sedan
Check to make sure the cable is put in correctly at the speed sensor. It can be a pain sometimes. If it is the cable or cluster that's broken, I have both of those parts fs in good working condition
Old Oct 26, 2010 | 05:41 PM
lokoking69's Avatar
cluster cant be bad! it runs by a cable nothing electronical.
first-check that it pluged all the way into the cluster
second-make sure the cable is pined into the VSS sumtimes the cable slips out with the vibration of the engine
third-if its not of the two above its your VSS.
Old Oct 27, 2010 | 10:49 AM
flatrex's Avatar
crx hatch sedan
Yeah that's true about the cluster. Well I have the speed sensor also if you need that.
Old Oct 27, 2010 | 06:23 PM
Blackd_out's Avatar
Thanks for the replies. I will double check the deal in the morning. I do remember the c-clip on the cluster side of the cable is broken, mandatory or no?
zoom zoom
Old Oct 28, 2010 | 07:09 AM
flatrex's Avatar
crx hatch sedan
Helps hold it in
Old Oct 28, 2010 | 12:38 PM
Blackd_out's Avatar
I want to say my cable is broken. It does not have the pin for the cluster, anyone around brandon with one?
zoom zoom
Old Oct 28, 2010 | 02:34 PM
flatrex's Avatar
crx hatch sedan
I'm in ybor I have one 7272780687 names Steven 15 bucks
