1999 Integra LS no spark???
Alright, I am pretty savy with cars and a lady her at work said her car died in the parking lot. Went out to look:
Car cranks, checked for spark... there is none. So typically next step is pull distributor check for gumming on cap, coil, ignitor in my book. But the rotor didn't spin, timing belt is fine, when dizzy is offer taper spins the rotor, rotor spins the taper, it is in correctly as it doesn't spin freely.
Anyone have any ideas, quick things to check etc.
Thanks
Thanks
Jump your service connector and look for these codes 4,8,9 anyone dizzy is bad.
Scroll down on this link and you will see troubleshooting from service manual flowchart
cel 4 CKP, cel 8 TDC, cel 9 CYP - Team Integra
Jdm b18c R LSD CRX si
TR "Old Skool EF" Member #96
JoKie TuNinG
RANGCRX BUILT TYPE R
StricKlyMT
727-510-6301
JoKie TuNinG
StricKlyMT
727-510-6301
See if timing belt is broke or you dont have the notches on dizzy lined up
JoKie TuNinG
StricKlyMT
727-510-6301
JoKie TuNinG
StricKlyMT
727-510-6301
If you dont want to pull timing belt cover just pull dizzy off and crank motor and make sure cam is turning
JoKie TuNinG
StricKlyMT
727-510-6301
JoKie TuNinG
StricKlyMT
727-510-6301
Pulled the cover, timing belt looks new. So its hooked up. Read your post #2 and looked at the link. I am still not really understanding this. Will 4,8,9 light up on the dash. I know this is stupid that I do not know the answer, but googling isn't telling me much, because its probably too obvious.
The jumper is on the passenger side? I guess its going to be a little hole I jab a paper clip into, kinda like the old auto seatbeat reset hole.
No you wont lose timing, but there is no point now since you know timing belt is good cause you pulled cover.
Pull distibutor back off and spin taper gear and make sure rotor spins. If yes put srew back in and reinstall lining up taper to camshaft( only goes in one way) and try it again making sure rotor turns
JoKie TuNinG
StricKlyMT
727-510-6301
JoKie TuNinG
StricKlyMT
727-510-6301
no spark,with no check engine lights....Sounds like the distributor coil...
Honda Valve Adjustments 50$
I TUNE KPRO AND S300
I DO NOT WORK FOR FREE
727-510-6301
Im not saying notches WENT I was making sure you put it back on right.
Here is how to check engine code.
Phearable.net - Electronic Fuel Injection Tuning Solutions - Hondata, Neptune, Crome, Uberdata, Ectune, AEM, Honda Tuning, Widebands, Fuel Pumps, Intercoolers, Turbos, LS/VTEC, ECU Chipping, Chipped Ecus, P28
I agree with Integra but when you see the price of the dizzy you will want to be sure.
JoKie TuNinG
StricKlyMT
727-510-6301
JoKie TuNinG
StricKlyMT
727-510-6301
