wiring question
Old Oct 20, 2010 | 09:47 AM
efkidd525's Avatar
I do what I do
Default wiring question
okay so heres the deal i got a 88 crx si OBD0 i dropped a z6 into it 0bd1 someone told me if i bought a jumper harnes obd0 to obd1 it still wouldnt work they said i had to do something with the dizzy
does anyone know anything about this? please help 17275511898
TR "Old Skool EF" Member #179
Old Oct 20, 2010 | 09:51 AM
BoostedRacerDad's Avatar
Pops
OBD0 OBD1
orange) (orange
white) (white
orange/blue) (orange/blue
white/blue) (white/blue
blue/green) (blue/green
blue/yellow) (blue/yellow
large white) (yellow/green <only color that is different
black/yellow) (black/yellow
blue) (blue
Jdm b18c R LSD CRX si
TR "Old Skool EF" Member #96
JoKie TuNinG
RANGCRX BUILT TYPE R
StricKlyMT
727-510-6301
Old Oct 20, 2010 | 09:58 AM
thegoldenchild's Avatar
There are two plugs to be concerned with, a 7 wire and a 2 wire plug. The lines for the distributor’s 7 wire plug can be pulled on both the engine harnesses. Pull the gray OBD1 7 wire plug for the distributor off the OBD1 engine harness and the replace the 7 wire plug on the OBD0 harness with it. Make sure to match the wires coming from the distributor with the matching colors being put into the 7 wire plug. As for the 2 wire plug, the plug has to be cut off the OBD0 harness and OBD1 plug spliced on.
