b20 swap in an ek coupe obd1 and 2?
Old Sep 5, 2010 | 12:15 PM
KushedRacer's Avatar
Default b20 swap in an ek coupe obd1 and 2?
i am buying a car with a b20 swap in an ek coupe. the cars idle is funny bouncing and a little high 900rpms and drops after coming off of it (letting off of the gas pedal. the car is converted to obd1 but the engine is obd2 the only thing on the engine thats obd2 is the distributor does that make sense? can an obd1 ecu run and obd2 dizzy? also i was told if i change the dizzy to an obd1 it will fix the idle... does that make sense?
Old Sep 6, 2010 | 07:04 AM
hello?
Old Sep 6, 2010 | 07:13 PM
Luis#15's Avatar
yea replace the dizzy the ecu and dizzy should always match. also try cleanin ur iacv for your rshared_pm problem, and check your vacuum lines
FOR YOUR MECHANICAL NEEDS GIVE ME A CALL OR TXT (813) 531-1387 (MOTOR/TRANNY SWAPS,ETC)
Old Sep 7, 2010 | 09:39 AM
will do
Old Sep 7, 2010 | 10:50 AM
iloveboosted's Avatar
TUNER
if not call me
JAY TUNING! YOUR tuning solutions
ECU Chipping and Reflash, Dyno Tuning,
CUSTOM MAPS
FROM OBD0 TO OBD1
ECU repairs
CLICK HERE >>> OUR FACEBOOK SITE
81360091974
