speed meter and rshared_pm not working? helpppp pleaseeeeeeeee
Old Aug 27, 2010 | 03:43 PM
chirby17's Avatar
Default speed meter and rshared_pm not working? helpppp pleaseeeeeeeee
the lights and works and emergence break light works but the speed meter aint working. the rshared_pm was bounce like crazy and now speed meter wont work or the rpm, i think is the vss? can yall help please thanks, and if yall think it is the vss where is it located?
Old Aug 27, 2010 | 04:04 PM
Jordan T's Avatar
┌∩┐(◕_◕)┌∩┐
on the transmission in most cases. probably the sending unit.
Old Aug 27, 2010 | 04:12 PM
Jordan T's Avatar
┌∩┐(◕_◕)┌∩┐
and you guys need to fix that "sharedPM" bullshit. cant be that hard.
Old Aug 27, 2010 | 05:16 PM
chirby17's Avatar
what do you mean the sending unit ? the speed sensor?
Old Aug 27, 2010 | 05:31 PM
SuburbanNoize's Avatar
Cold Ass Honky
Chirby, you need to start posting your stuff in Honda/Acura Tech man. Youll get more specific advice in there.
TR DC CREW MEMBER #4
StricklyMT.com
Performance Specialist
727-510-6301
Old Aug 27, 2010 | 05:45 PM
chirby17's Avatar
thanks ill do that
Old Aug 27, 2010 | 06:21 PM
chirby17's Avatar
i still need helpp people
Old Aug 27, 2010 | 07:31 PM
iloveboosted's Avatar
TUNER
bring it to our shop we take a look at it
JAY TUNING! YOUR tuning solutions
ECU Chipping and Reflash, Dyno Tuning,
CUSTOM MAPS
FROM OBD0 TO OBD1
ECU repairs
CLICK HERE >>> OUR FACEBOOK SITE
81360091974
Old Aug 27, 2010 | 07:54 PM
BoostedRacerDad's Avatar
Pops
Is the CEL ON?
First check whether either fuse 24 (15A) (w/ SRS) or 12 (15A) (w/o SRS) is blown. Assuming the VSS is fine (usually the VSS is bad in this situation), next check whether there is an open in the YEL/BLU wire powering the speedo. If all of the latter are fine, then you likely need to replace these gauges.
Jdm b18c R LSD CRX si
TR "Old Skool EF" Member #96
JoKie TuNinG
RANGCRX BUILT TYPE R
StricKlyMT
727-510-6301
Old Aug 27, 2010 | 08:06 PM
chirby17's Avatar
thanks its a coupe 93 dx with a d15b engine
