need help, brake lights wont go off
Old Jul 14, 2010 | 04:59 AM
Tlassiter's Avatar
Default need help, brake lights wont go off
My cars brke lights wont go off. even the 3rd brake light stays on. its a 95 civic does ne one kno what could b wrong
Fresh Dc
Old Jul 14, 2010 | 05:17 AM
integra's Avatar
90% grind 10% sleep
check by the brake pedal. there should be a lil plastic peice that broke. it pushes a button in,that turns off your brake lights.
Brake lights stay on...how I fixed them - Honda-Tech
Honda Valve Adjustments 50$
I TUNE KPRO AND S300
I DO NOT WORK FOR FREE
Originally Posted by THE_ONE
Old Jul 14, 2010 | 06:58 AM
DRMORTY's Avatar
Once Ruled The World .l..
You'll see some little blue plastic pieces on the floor.
It is what is left of your Brake Light Switch push plug.
On the brake lever if you follow it up, there is a switch and a metal plate on the lever itself where the plug went, and now the is an open hole on the plate. replace the plug with a small bolt & nut. the when the brake pedal is released it pushes the switch button back it... and your done...
2 Minute FIX IT
TR
"Old Skool EF & DA Crews" Member #46
TR "Wagovan Club" Member #1
Old Jul 14, 2010 | 08:05 PM
Red2GDSM's Avatar
In the making...
Just had to fix this in my coupe. takes 2 minutes as long as you have a nut and a bolt. slip it in and your done
Originally Posted by solsi2000
does this magical box come with a pussy magnet?
Originally Posted by NISSAN
need to fill ur vtec fluid back up, thats why, its located in the back of the block, the little black box.
^^Lmao this shit was just funny
