confused on dsm injectors
Old Jun 25, 2010 | 04:43 AM
Importracer13's Avatar
99CivicSi
Post confused on dsm injectors
Ok I got a set of dsm 450cc blacktop obd2 injectors for my New build question
is there goin into an em1 so do I need to run a resistor box... I've read on h-t that people are running them with out one but then I'm Reading that u need one in order for it to run right cuz there low independence ... And do I have to modify the injectors to fit the clips?
I <3 BOOST
EM1 Crew Member #16
OVERDOSE CUSTOMS FROM BASIC MAINTENCE TO ENGINE SWAPS, CAR AUDIO , PAINT AND BODY
Honda,Toyota, Nissan,Ford,Chevy Dodge, Everything
14525 62nd streeet north Unit 3&4
Clearwater FL 33760
CALL OR TXT 727 465 8295
Iggy Azeala
Old Jun 25, 2010 | 06:26 AM
FrodoGT's Avatar
Found the Vtec switch.
You must run a resistor box or risk burning out your injector driver.. Also obd2 clips will not fit on the dsms, you'll want obd1 clips or the mitsubishi ones.
TR Old Skool EF Crew #24
Old Jun 25, 2010 | 06:34 AM
99CivicSi
Ok thanx man where can I get a resistor box and around how much are they?
I <3 BOOST
EM1 Crew Member #16
Clearwater FL 33760
Iggy Azeala
Old Jun 25, 2010 | 06:35 AM
FrodoGT's Avatar
You could get one from a 3rd gen prelude, a DA integra, or a civic/crx hf or si. Shouldnt be more than 20 bucks MAX.
The added resistance is similar to setting up speakers and amplifiers, less resistance equals more power flow, and will overwork the driver circuitry.
Old Jun 25, 2010 | 06:44 AM
99CivicSi
Ok I understand now just had to put it in audio language lol.. Thanx again bro
I <3 BOOST
EM1 Crew Member #16
Clearwater FL 33760
Iggy Azeala
