Passenger door won't open
theres something wrong with the locking mechanism in my passenger door which isnt allowing me to open it from either side with the key or by any combination of unlocking the outside lock with the key or the inside lock manually or electronically.
i'm trying to figure a way out to either get the door panel off or the entire door off so i can get to the insides. i've got the door hinge bolts off so the front half is off but its being held on by the pin that holds the spring mechanism (or whatever it is in there) on so the front half isnt coming off. when i got the front half loose it left a little room for the door panel to move but the dash and the rear half of the door being closed are both blocking it from coming out.
if anyone has any other ideas i would greatly appreciate it. my friends are getting tired of climbing in through the driver's side.
thanks,
dimitri
thanks,
dimitri
Nissan North America - Canton
there arent screws you can get to from the outside.
never mind guys, i ended up ripping the door panel off. time for a WTB door panel thread...
i took a door panel off a car at the junkyard yesterday when the door was jammed shut. i didnt break the door pannel either... there was no dash tho.
i ended up just using a hammer and forcing it open because it wouldnt open at the latch.
Originally Posted by Empire oh no. another ass hole 240...
