PDM Racing Lower Control Arms?
Old May 23, 2010 | 10:24 AM
240gun91's Avatar
Default PDM Racing Lower Control Arms?
I recently had a failure in my passenger side tie rod, but when I was under the car replacing the tie rods I also noticed the ball joint on my lower control arm on the same side had ruptured. These control arms are only a year old from PDM Racing.com. The year before this I had replaced the lowers for the same reason.
So after two pairs of lower control arm ball joints rupturing within a year, I wonder if its PDM racing parts or if this time the failure was caused by the tie rod coming loose while driving and putting to much stress on that ball joint?
I need to replace them now, and PDM has a great deal, so is it worth it to buy from there again or should I just try to have the ball joints replaced and pressed with something higher quality?
Any info would be helpful.
I'm a graphic designer, but I enjoy a good drive.
Really need some ill graphic design? Contact me for my freelance work. View my Blog here.
Old May 23, 2010 | 10:30 AM
osama tim laden's Avatar
kings cannot fall.
is the ball joint itself bad, or just the boot is torn?
you can replace the boots, or buy just a ball joint to replace it.
Old May 23, 2010 | 05:16 PM
240gun91's Avatar
I'm not sure if the actual ball joint is bad? I just see the rubber boot has burst and the grease came out and i'm guessing has contaminants in there now because the car has the loud clunk when braking and turning.
Old May 23, 2010 | 07:05 PM
asia989's Avatar
Why So Serious?
clunk might be the tc rods
No Front Bumper Mafia crew#1 since 04'
The original 350Z Blue 240sx
Old May 23, 2010 | 07:08 PM
A-ron's Avatar
(SHIFT-YOUR SHITS WEAK)
^ i second that note
Drifting:
most fun you can have
with your pants on.
Old Jun 11, 2010 | 06:46 PM
Boats N' Hoes's Avatar
pp ball joints are near bomb proof.
Originally Posted by CurbJacker
great a new fucking band wagon... now every fucking 240 and ricers gonna be saying " im going LS1" i hate this shit... ill stick to SR20... teenie bopers i swear.
So_Chem WE RUN SHIT!
[/CENTER]
