Bouncing RPMs?
Old Jan 30, 2010 | 05:09 AM
David48's Avatar
I <3 usdm
Default Bouncing RPMs?
The black car I've been working on is developing a weird problem. When I rev it up to 2500RPM it starts bouncing between 2500 to 2200. It's kind of like when you hit the speed limiter in 4th or 5th gear. But it still revs higher. It doesn't have any trouble getting past 2500, but I'm just wondering why it's doing it. Could it be bad gapping on the spark plugs? btw, it's an 89 single cam.
Potato
shit got all davided up.
Old Jan 30, 2010 | 05:40 AM
Z350man's Avatar
Blah Blah Blah
sounds electrical. check your grounds and make sure you have good connections everywhere
Old Jan 30, 2010 | 07:59 AM
TpaS13's Avatar
Powered by Canon
check the MAF as well, i know they start bouncing around 2500....yours could be on its way out idk just a thought
-Rob Plympton
Canon EOS 40D---EF 28-135mm f/3.5-5.6 IS---EF 50mm f/1.8 II---Sigma 18-55mm F/3.5-5.6---Strobist gear
flickr
Old Jan 30, 2010 | 09:28 AM
David48's Avatar
I <3 usdm
Are the single cam and dual cam mafs the same? If they are, then I can swap it out with the one in the white car and see if that's it.
Potato
Old Jan 30, 2010 | 09:37 AM
TheTanMan's Avatar
You can call me Tanner.
Google it, homeslice.
I don't have a 240, so I can't help.
I do hope you solve the problem though.
Damn, I wanna go drive the truck a bit.
iSlide.
Old Jan 30, 2010 | 03:51 PM
TpaS13's Avatar
Powered by Canon
I dont think so, s13 dohc mafs are cheap though
-Rob Plympton
flickr
Old Jan 30, 2010 | 03:57 PM
-Mike's Avatar
Formerly IThaJokaI
A DOHC maf would do him no good, cars sohc.
I don't think its your maf David, Ill see if I have a spare to check though.
Old Jan 30, 2010 | 03:58 PM
David48's Avatar
I <3 usdm
Thanks Mike. And yeah, the problem is on the Single cam 240.
Potato
Old Jan 31, 2010 | 06:50 PM
TpaS13's Avatar
Powered by Canon
oh lol my bad i guess i wasnt payin attention...
-Rob Plympton
flickr
Old Feb 17, 2010 | 09:20 AM
mex08's Avatar
on the back of the intake modifold i think its called the intake throttle anyways take dat out and clean it dats wat was wrong wit my 240
