Spindle
Old Oct 30, 2009 | 08:14 PM
Tlassiter's Avatar
Default Spindle
Ok im replacing my spindle and i have everything off but the bottom bolt on the spindle, i got the nut off but the spindle wont pop out. iv tried a hammer, jacking it up on it, a fork seperater everything and it wont come off. anyone have an suggestions or should i just take it to a shop?
Fresh Dc
Old Oct 30, 2009 | 08:43 PM
EconoBox's Avatar
Four Door Mafia
Go rent an actual ball joint popper. It goes on and you tighten it with an impact gun or socket and it pops the ball joint right out. Or with the fork separator that you already have make sure it is going in all the way(or the right size one)... you may need to hit it harder. Chances are you will need to replace that ball joint once you get it out.
ECU Chipping, Tuning, Custom Wiring, and any other automotive needs. PM me for a quote.
Hmotors/Hondata/Hasport/JHPusa/PasswordJDM
stores. Most parts in stock or 1 day away!
Old Oct 31, 2009 | 05:02 AM
integra's Avatar
90% grind 10% sleep
use a bigger hammer. Not one with the hook on the back side.
Honda Valve Adjustments 50$
I TUNE KPRO AND S300
I DO NOT WORK FOR FREE
Originally Posted by THE_ONE
Old Oct 31, 2009 | 09:26 AM
SUPAFLY's Avatar
use a sleg hammer amd hit it lik twice pop its out
TR "Old Skool EF" Member #152NO BOOST!!!!JUST MY FOOT AND THE BOTTLE!!!!!CRX SiR
88 crx dx-wrecked
91 crx si -project 300 whp allmotor-solddd
95 teggy-parting out
91 ex 4 door -sold
97 ek civic dx boosted-400whp
98 teggy gsr-dd
8137704076 b series parts for sale let me kno what you need
Old Oct 31, 2009 | 09:32 AM
custom240sx's Avatar
DC Crew Member #1
Heat it up. We torch the bolt and then smack them and they pop right out. Don't melt the rubber boot though. If they were installed correctly they would juts pop right off without a fork.
Old Oct 31, 2009 | 05:44 PM
Tlassiter's Avatar
i have already torn it up. the spindle is no good so im doing whatever to get it out
Fresh Dc
Old Oct 31, 2009 | 10:17 PM
mogo21's Avatar
use a ball joint separator fork if that can do it npthing can
Old Nov 2, 2009 | 02:57 PM
Tlassiter's Avatar
nothing worked. it needs to be pressed out
Fresh Dc
Old Nov 2, 2009 | 06:01 PM
DC Crew Member #1
It needs to be heated up and you grow some muscles lol...they will come apart with a pickle fork, lots of heat from a handheld torch, and some muscles.
