o2 sensor just went out
is there any real reason to replace this thing?
Driving definitions: Understeer is when you hit the wall with the front of the car and Oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall and Torque is how far you take the wall with you.
yes. In most cars, the ecu uses information from the o2 sensor for adjusting fuel trims. Without this input, the ecu will likely revert to a default setting, likely causing poor fuel economy and a loss in drivability.
If those things do not bother you and the yellow light doesn't piss you off, sure, drive around, it'll probably be ok.
Fuel sensors is going to determine your fuel ratio. Kinda important to prevent from running too rich or too lean. In other words you're are probably going to be getting some shitty gas mileage.
Shit that means i need to replace it. OH what fun!
Definitely need to replace it. Not only will it hurt gas mileage, but it will probably affect HP and torque (especially below full throttle) and can make your catalytic converter burn up/get clogged.
Look up definition of stupidity in the dictionary and it says "see below"
My ride: 2000 Grand Am GT
Supercharged, dropped, RK sport kit, Baer brakes, riding on 17" forged centerlines.
Check my car domain page if ya have time. http://www.cardomain.com/ride/2386767
