Torque Converter Riddle
Old Jun 22, 2009 | 12:23 PM
byondevl's Avatar
Made Of Scars
Default Torque Converter Riddle
Test fit TC to flexplate out of tranny...every hole lines up
Install tc in tranny..it seats as far back as it will go, bolt hole all line up but one. WTF'n hell.?
Old Jun 22, 2009 | 12:29 PM
IamSuprAwsum's Avatar
Blasphemer
Time to break out the drill. lol
Seriously though, I dont know much about auto stuff. That sucks man. Hopefully someone will chime in and let you know. Maybe bad production of flexplate or TC.
(USER WAS BANNED FOR THIS POST)
Old Jun 22, 2009 | 12:32 PM
byondevl's Avatar
Made Of Scars
But holes line up perfect out of tranny. I dont get it.
Old Jun 22, 2009 | 01:07 PM
shinysideup's Avatar
TR Balla Donor Supreme
Check the angle of the dangle. The trans isnt seated and off-plane.
Old Jun 22, 2009 | 02:01 PM
byondevl's Avatar
Made Of Scars
I have a feeling the flexplate is the problem. I may have got crazy with the threadlocker, the back of the flexplate and crank are covered in a film. I dont think the flexplate was could seat all the way.
Old Jun 22, 2009 | 03:15 PM
red vert's Avatar
welcome to Tampa Ricing
If bell isn't going all the way square to the block, check to make sure converter is seated.
Old Jun 22, 2009 | 07:17 PM
byondevl's Avatar
Made Of Scars
Converter is seated all the way, bell to block clearance is fine. THis mutherfucker just wont line up. I don't get it.
Old Jun 22, 2009 | 07:30 PM
Tiffiny's Avatar
I can fix your bullshit
I have learned over the years to walk away and sleep on it
its much clearer in the morning
Old Jun 23, 2009 | 01:01 AM
GNs-r-slow's Avatar
Bondsman
Put some hair around it
Old Jun 23, 2009 | 01:07 AM
GNs-r-slow's Avatar
Bondsman
Try to put the converter to the flexplate out of the tranny (test fit) to make sure the snout of converter is "seating" in the crankshaft properly. I seen were you had to remove a pilot bearing from there, be sure there is no burrs in there HTH
