Header gasket
Old Mar 26, 2009 | 08:19 AM
Black_notch's Avatar
Default Header gasket
Any tips? I have Hedman LT's and the driver's side is stating to talk to me. I'm gonna try to tighten the bolts but if I have to replace the gasket is there anything I should know (like if its a complete P.I.T.A!!!) Like I expect, LOL.
1995 Black on Black Cobra- waiting to awake.
Old Mar 26, 2009 | 08:26 AM
95coBraSVT's Avatar
banana republic
Is it on the Bullit?
Originally Posted by rotarykidd
maybe i just like rainbows and puke, who says it has to be a gay thing?
Old Mar 26, 2009 | 08:32 AM
Old Mar 26, 2009 | 08:37 AM
95coBraSVT's Avatar
banana republic
Then it's going to be a bitch. Sorry.
If it was on a 95 or older...it would be relativly easy.
Old Mar 26, 2009 | 08:42 AM
Stealth Mode's Avatar
Still CREEPIN
i know a guy that double stacks his header gaskets. seems to work, but u dont have much room under ur hood to play around. good luck man
TurboRAM Member #5
24psi & Stable
GET SOME
Old Mar 26, 2009 | 09:20 AM
MiDiablo's Avatar
Assuming the leak is at the block?
Get an extension, a long extension, and a swivel or three
Old Mar 26, 2009 | 02:19 PM
Mars_302's Avatar
Race Photographer
I had good luck with the mr gasket graphite ones.
Old Mar 26, 2009 | 07:30 PM
racingrick's Avatar
POTENTIALLY FAST
some people might laugh but get the cheapo aluminum looking header gaskets. notch the holes (cut the bottom out to look like a c)
loosen your headers bolts but don't take them out. carefully drop the gaskets down onto the bolts. tighten. I've done it a million times and it always seems to work unless you have a really warped header.
Old Mar 26, 2009 | 08:44 PM
herrcomestrouble's Avatar
I have Percys header gaskets on my car. They makes a reusable soft header gasket. Its thick and crushes down nice. You can use them 8-10 times before they have to be replaced.
Or u can try.....
I havn't tried on a 5.0 yet. But a few motorhomes I have worked on in the past. I have thrown the exhaust manifold gasket away and used rearend grease as a "gasket." Just a good bead all the way around the ports on the head. Then crank the engine, DONT rev it, just let it idle and get up to temperature, then retighten the bolts. Works like a charm on the bigblocks....
Sn95' Tripple Black Cobra
Mods:Heads/Cam/Intake/Exhaust...just your typical stock mustang...
Old Mar 27, 2009 | 08:02 AM
Thanks for the info, I'm gonna tackle it this weekend. Maybe I can go through the wheel well on some of the bolts! Keeping fingers crossed!
