Rod bearings????
Old Dec 24, 2008 | 04:26 PM
EfWorld's Avatar
Default Rod bearings????
I have a sohc ZC with 1 bad rod bearings. i need to know what bearings to use. im told that the d16a6 are diffrewnt and so are the dohc ZC motors.
Anyone replace rod bearsings on this motor before? non vtec
send me a pm
TR "Old Skool EF" Member #48
99 Mitsu Eclipse GS-T DD
91 Honda CRX Si
91 Honda Civic Si
91 Honda CIVIC Si FOR SALE da front brakes. mint interior, 650 buks
Old Dec 24, 2008 | 06:20 PM
rangcrx's Avatar
engine building &best
nope they are all the same d16a1/a6/z6/y8/y5/y7
i love AUTOZONE
Old Dec 25, 2008 | 03:48 AM
Skee's Avatar
if you have 1 bad bearing dont just replace over it pull the crank and have it checked or you will end up in the same spot with another spun bearing
Custom high amp Alternators.. pm me
Old Dec 25, 2008 | 06:07 AM
mtber's Avatar
This is correct. Your oil pump assembly may be faulty, your oil pickup & chambers are probably contaminated also.
