header help
Old Aug 27, 2008 | 04:31 AM
markstheman365's Avatar
cant slide
Default header help
"1236_1.jpg - Image - Photobucket - Video and Image Hosting"
theres a pic
i want em installed on my civ.
hit me up
813 770 1458
Old Aug 27, 2008 | 06:19 AM
ekhatchboy's Avatar
Redrocket part 2
bro it is cake you could do it yourself. you will need ...
12mm socket
o2 socket
ratchet
and extension
use the o2 socket to remove the o2's there is one in the front and if you have a secondary o2 it will be behind the motor on the exhaust. then you will unbolt the 2 bolts at the flange going to the exhaust then you remove the 12mm nuts that bolt the header to the head. at this point the header should remove quite easily. then the install is exactly the same but backwards. when installing remember to leave the nuts loose that go to the head so that you have a lil play at the flange area then go back and toqrue everything down to spec
Married to EkCoupegirl
Current Cars
05 ZX6R FOR SALE! Help me pay for school PM me for info.
95 Civic EX 4dr- D.D.
99 GMC Sierra 5.3l ext. cab. Under construction
05 Kawasaki Ninja ZX636R Plasma Blue
