sr20det help
Old Jun 8, 2008 | 04:34 PM
WhiteNgold's Avatar
is underwater
Question sr20det help
got my sr running awesome. got 255lph fuel pump, fmic, greddy type rs bov, etc. 10psi boost. runs and idles great. drive it... stop... great. run it hard and stop for a minute and it starts smoking. doesnt smoke under load, only at idle. and when its smoking and u give it some gas it smokes like crazy.... embarrasing. if i drive it normal for a bit it stops the idle smoking. btw... its oil. not fuel, not coolant....oil. compression holds evenly across the board. dont know if theres some typical sr20 thing or somethin. im thinkin its turbo seals, but im not sure how to tell(it doesnt have shaft play). ne info will be great and REP WILL BE GIVIN TO THOSE THAT HELP. thnx
Old Jun 8, 2008 | 04:37 PM
jdmpete's Avatar
3 rotor whachakno
yea it sounds like your turbo went..
your a fanboy
I'M KILLING IT
Old Jun 8, 2008 | 04:40 PM
4wheeldriftS13's Avatar
February - Ride of the Month
Yeah that definitely sounds like turbo seals.
RIP Tim Aldrich
Old Jun 9, 2008 | 01:34 AM
JaxS13Racer's Avatar
Sold my sol for Silvia
I had the same problem, and thought I was going to have to replace the turbo but I was changing the oil the other day and looked at the oil return line coming off the bottom of the turbo and going in to the block and it had slipped a little letting oil squirt out a little and causing it to smoke. I'm assuming that yours has a small rubber line for your oil return like mine, if not then just ignore me. good luck
Old Jun 9, 2008 | 01:42 PM
WhiteNgold's Avatar
is underwater
ok... so i wasnt far off. what r my options other than another t25? anybody got a t28? what should be my next step?
Old Jun 9, 2008 | 02:57 PM
jdmpete's Avatar
3 rotor whachakno
you could go t3/t4,or a gt2871r,also a hks gt2540 or just keep it stock with a t25..
your a fanboy
I'M KILLING IT
Old Jun 10, 2008 | 06:14 AM
WhiteNgold's Avatar
is underwater
ok, but everything is pretty much stock. wouldnt a bigger turbo be overkill? how hard is it to rebuild?
Old Jun 10, 2008 | 06:33 AM
vanilla gorilla's Avatar
I have a sc50 turbo that needs a rebuild. You could always upgrade turbo, manifold, ect.
I've learned that when something goes bad, just upgrade to something better.
Old Jun 10, 2008 | 07:59 AM
jdmpete's Avatar
3 rotor whachakno
t28 would be the best for you then since your motor is stock..
your a fanboy
I'M KILLING IT
Old Jun 10, 2008 | 04:42 PM
T28 is awesome because it bolts to the stock manifold. No need to buy another manifold. But requires different inlet and outlets. a/f will be an issue hints why people upgrade to larger injectors and a Z32 300zx MAFS sensor
RIP Tim Aldrich
