Chassis & Suspension Tech Cages, braces, suspension set up and more
skunk2 springs, stock shocks???
Old Apr 3, 2008 | 06:40 AM
NIGHTRIDA91's Avatar
Default skunk2 springs, stock shocks???
ok i want to buy a good suspension setup and cant really make up my mind on what i want to buy...i no im not going to buy those shitty coilovers on ebay... but what came to my mind was if i buy skunk2 lowering springs and a camber kit could i get buy with just using my stock shocks for now?? then in like 4 or 5 months later throw in like some kyb's or tokico blues...? just let me no what is as good idea and i dont want to wait to buy both cuz i just got new wheelz and i have a HUGE gaps in the fender wells.....thanks...
Old Apr 3, 2008 | 07:08 AM
didnt answer my question...any 1 else??
Old Apr 3, 2008 | 11:03 AM
treekiller's Avatar
legend behind the cowl
aftermarket lowering springs will work fine, but get a set of good sport shocks will make the springs actually work, and tokiko blues and kyb replacement shocks, while better then stock (mostly because they are new) are not sport oriented minimum is kyb agx then illimina then bilsten and koni...
Old Apr 17, 2008 | 07:31 AM
I concur with treekiller.-Bob
Old May 10, 2008 | 06:10 AM
drico27's Avatar
I have skunk2 springs with stock shocks lowerd inch in the front inch and half in the back on my 95 integra, i let my girlfirend dirve my car for a week, after that my shocks were blown,
Old May 10, 2008 | 01:38 PM
If the shocks were good to start with, it's hard to believe they could have
been blown out in 7 days, especially since the car wasn't really slammed,
but we don't know much about her driving......
Some people have brought cars to me for aftermarket spring installations where the shocks were bad to start with............and for sure, when the shocks are bad at the start, the shocks won't get better just because I install aftermarket springs for someone........
There is a difference in blown out and worn out....... worn out is where the shock ceases to damp any more. Blown out is where oil is leaking past the seals. Your definition may vary....
When oil is leaking past the seals, I don't know anything that can be done except toss the leaking shocks out.
If all they are doing is showing a loss of efficiency, sometimes shocks can be rebuilt................but only if your rebuilder has been doing it long enough to know what he is doing..................
People who don't know about shock rebuilding are better off to just go buy new ones, instead of complaining that since THEY can't rebuild shocks,
they think that neither can anyone else......-Bob
Old May 10, 2008 | 10:00 PM
treekiller's Avatar
I agree with S.H. when it comes to cornering shocks are as important as springs if not moreso. and most shocks cannot deal with a cut-spring lowered car since they bottom out the strut/shock assy. now a set of shocks designed for the short travel, those will not die..
Old May 13, 2008 | 01:23 PM
DANGERANGER's Avatar
Shop Bitch
I have new sets of Skunk 2 springs and coilover kits coming in on a good deal if interested. I can get u the cheaper KYB GR2 struts also and have a pretty decent inexpensive kit. Also have the Camber kits, which I suggest also. LMK if I can help
