E-Brake Problem... Can Sum1 Help?
Old Jan 6, 2008 | 04:50 PM
3m0k1d's Avatar
Can't Take It With You...
Default E-Brake Problem... Can Sum1 Help?
My E-brake works and all but its not as tight as it should be, when I park and engage the e-brake you can still move the car a little bit... does anyone know how to make it tighter so the car wont move at all?
Old Jan 6, 2008 | 05:59 PM
tai mishuu911's Avatar
rut roh
take off your center console and re adjust it?
N/A GSR on its way.
StricKly MT 727-510-6301
WIREWORX 407 388-5809
Old Jan 6, 2008 | 06:55 PM
3m0k1d's Avatar
yea but what do I do? jus tighten the nuts on the cables?
Old Jan 6, 2008 | 06:59 PM
rangcrx's Avatar
engine building &best
buy new rear brakes,or if they are good adjust the rear brakes i would not adjust the Ebrake itself
i love AUTOZONE
Old Jan 7, 2008 | 04:12 PM
JDM son!'s Avatar
Professional Hustler.
if you go in reverse and pull the e brake up to a complete stop it tightens it up. just do it a few times
MONEY IS THE MOTIVE.
Old Jan 7, 2008 | 04:44 PM
3m0k1d's Avatar
Ok I took the consule out and tightend the spring and it seemed to help alot, could somthing bad result from that?
Old Jan 7, 2008 | 05:02 PM
rangcrx's Avatar
yes if your brakes are going then all your doing is going to dig into the rotors unless you got money then nope nothing bad
i love AUTOZONE
Old Jan 8, 2008 | 08:01 AM
3m0k1d's Avatar
oh no, I replaced all the pads and shoes about 6 months ago and the master cylinder about 3 months ago so im sure the brakes are all fine...
Old Jan 8, 2008 | 11:09 AM
dippincrx's Avatar
save the s.o.h.c
did you adjust them when you changed them, would have done that before messing w/ the ebrake cable
Old Jan 8, 2008 | 11:49 AM
3m0k1d's Avatar
My uncle changed 'em so im not sure... ill have to ask him
