some truck questions.
Old Oct 28, 2007 | 01:10 PM
hideinginfl's Avatar
Is moveing on up
Default some truck questions.
i have an 80 f100 i just picked up with a carbed 302 in it, 9in rear, its a 3 speed with manual brakes and manual steering, now the clutch is a setup iv never seen its moved by a few rods connected to the pedal. my questions are as follows, does any one know if i can just put a booster and hook up the vacumme to it and have power brakes? can i find the steering box and pump and have ps? biggest question can i put any 5 speed in it from a ford, obviously if its hydraulic id have to add that system id have to install the other stuff for it, but what about a t-5 form a stang cause its cable actuated how bad would that be to put in, cause with the speed on the high way that thing sucked the gas down, if i went with the t-5 which would be fine wold i need to change the clutch and flywheel or no. help would be great.
Rip Kevin "Slo-si" Gonzalez 9-13-06
Old Oct 29, 2007 | 03:22 AM
Is moveing on up
hmmm guess no one knows, well ive done a bi of surfing and found the make conversion kits to go from the rod actuated system to a cable system.and from what ive read canust just put a power booster and master on it and have power brakes.
Old Oct 29, 2007 | 03:55 AM
shinysideup's Avatar
TR Balla Donor Supreme
Why not dump teh '80 if you dont want manual everything, and pick up an 86+.
Old Oct 29, 2007 | 04:00 AM
Is moveing on up
cause i got a good deal on this truck, and id be more fun just to make it how id like it. i dont mind the manual steering i can live with that, but the manual brakes take some getting used to. and im keepin the trans manual i just want a 5 speed in it.
Old Oct 29, 2007 | 04:08 AM
harold harper's Avatar
h9
we have a couple older trucks at are junkyard with the parts you need 813 672-8117 ask for eddie
Old Oct 29, 2007 | 01:14 PM
Is moveing on up
what junk yard, ill deff be checking it out this weekend
Old Oct 29, 2007 | 03:52 PM
h9
express used auto parts
Old Oct 29, 2007 | 04:02 PM
Is moveing on up
wheres that at
Old Oct 29, 2007 | 04:09 PM
h9
6821 78th st.riverview,fl
Old Oct 29, 2007 | 05:15 PM
Is moveing on up
thanks. ill be stoping in this week end
