o2 readings
Old Jul 19, 2000 | 07:00 PM
FastFour's Avatar
anyone ever hear in accuality of o2s being over a volt. As I posted on tampabaydsm im getting like 1.02 in all rpm ranges except 6k were it drops to about .98 This is on 18psi on the big16g. Heres the mods http://eclipse.isni.net/mods.htm
My egts are around 1300 at 6k too! How can this be?! When I first got the turbo the temps were higher like would goto 1500. You guys think maybe because of this heat? Well all the testing I did was at night were it was fairly cool out. Could the computer have changed the fuel amount to compensate as it learned or something? I know the more boost the more fuel cause the fpr closes more but..
Frank
99GS-T
Frank
99GS-T
Old Jul 19, 2000 | 07:14 PM
FastFour's Avatar
test to see if my pic works on the bottom
<A HREF=http://eclipse.isni.net/mypics/sidehrthumb.jpg
Frank
99GS-T
http://eclipse.isni.net TARGET=_blank>http://eclipse.isni.net/mypics/sidehrthumb.jpg
Frank
99GS-T
http://eclipse.isni.net</A>
Frank
99GS-T
Old Jul 19, 2000 | 07:16 PM
gsx eclipse's Avatar
hey frank i couldent see the pic at the bottom.. but have you tried asking glen i know he had something similer to that that.. well i think he did
alex galvan
13.89 @ 91mph Stock!
Old Jul 20, 2000 | 04:51 AM
16gAWD's Avatar
Buy a Super AFC. Your running Rich. I can get mine up that high sometimes 1.04. Do you have any of the honeycombs out? To get the image to work use img tags instead of url
16gAWD
97 Talon TSI AWD
James
Just another unreliable fast DSM
http://www27.brinkster.com/awd16g/
Old Jul 23, 2000 | 01:03 PM
FastFour's Avatar
kewl at least i know someone else has voltage over a volt no i havent pulled any honeycombs out because i heard they make you idle bad. Also because i want to make sure i dont lean out on top end. Yes I agree i need an afc I need lots of things still.
Frank
99GS-T
[This message has been edited by FastFour (edited 07-23-2000).]
Frank
99GS-T
Old Jul 23, 2000 | 01:24 PM
FastFour's Avatar
woohoo finally got the pic to work!
Frank
99GS-T
Frank
99GS-T
Old Jul 24, 2000 | 05:11 AM
16gAWD's Avatar
You can pull out the bottom one and the Idle will be fine. When you get the SuperAFC you can pull the side ones out. Check to see if that screw at the buttom of the MAS is all the way out that can help.
16gAWD
97 Talon TSI AWD
James
