Clutch or Tranny?
Old Sep 19, 2007 | 08:19 AM
DD.'s Avatar
DD.
Administrator
Default Clutch or Tranny?
So heres the story...
Whenever im in high rpms, say around 6-7k...and im shifting from 2nd to 3rd gear, i sometimes cant even get into the gear. Most of the time it grinds horribly. 2nd and 5th gears do it sometimes too.
BUT...If i let the rpms drop down about 2krpms before slamming the gear, it goes in ok.
...SO could this be the Clutch or the tranny? Remember when i let the rpms drop a little, it goes in ok. I want to know before i drop the tranny.
Help is appreciated, thanks in advance.
-Darrell
Old Sep 19, 2007 | 09:11 AM
sleepinsol's Avatar
starting over
sound like ur tranny....
Old Sep 19, 2007 | 11:48 AM
PooN_Lude's Avatar
Try running some GM Synchromesh in the tranny, shit cures cancer son.
Btw- doesnt sound like your clutch is the problem, do the gears grind at all in low rpm?
Old Sep 19, 2007 | 11:51 AM
casanova1514's Avatar
civic97
^^^^ on what poon said synchromesh is the shit check tranny fluid it might be low/// do a flush
Old Sep 19, 2007 | 11:52 AM
Gixxer's Avatar
Hide your daughters
My old LS tranny did that and when I took it apart I could see the syncros were all worn down pretty bad.
Old Sep 19, 2007 | 11:56 AM
DD.'s Avatar
DD.
Administrator
Ive heard about the GM mesh. That may not fix the problem but it may make it a little better.
I could get that at autozone correct?
I just wanna try a few things and get some ideas before i have to drop the tranny and replace a clutch. Cuz if its a tranny, ill just swap out the whole thing.
Old Sep 19, 2007 | 12:30 PM
PooN_Lude's Avatar
I always get mine from the GM dealer, Da ZoNe may have it though
Old Sep 19, 2007 | 12:45 PM
Gixxer's Avatar
Hide your daughters
FYI: Pennzoil syncromesh is the exact same ish for waaay cheaper.
Old Sep 19, 2007 | 12:52 PM
nocomply540's Avatar
is retired...
He speaks the truth! I had a pretty moderate grind in my tranny and flushed it out a couple times with Honda MTF and it's not done it in over almost two years.
"I just drank a fifth of vodka. Dare me to drive?"
Don't take life so serious. It's not like were getting out of it alive anyway.
Old Sep 19, 2007 | 03:21 PM
TSX24L's Avatar
if this is a dseries tranny, i have one at my work. Just needs the input shaft bearing and mainshaft bearings. I have already replaced all the seals including axles seals new t/o bearing etc.. all syncros good no shifting problems at all. I just haven't ordered the bearings yet that are like 100.00 for both. If you want to pay for those bearings I can reassemble it for you and sell it to you for another 100.00. Total being 200.00 for a rebuilt transmission. Its from a ex. Its super clean to. I would though get a new disk though.
