fwd vs rwd sr blocks
Old Sep 5, 2007 | 11:22 AM
keaser06's Avatar
TR = Drama = LOL
Default fwd vs rwd sr blocks
im thinking about picking up a spare block to build because i think mine is starting to go bad.. need to do a compression test still.. but if i get a rwd block will it still work in my car? (see sig) i know the head is different dont start telling me about that.. im talking about block, crank, rods, and pistons. only parts im interested in
Old Sep 5, 2007 | 11:30 AM
keaser06's Avatar
TR = Drama = LOL
oh btw i dont want fanboys just jumping in here saying no it wont work because they are different motors i want someone with actual knowledge to tell me the answer and if they arent the same please explain i want to be able to walk out to my car and see the difference you are talking between the rwd and fwd.. i believe the blocks are the same its just the heads that are different but i would like to know for sure. if they are the same im going to try and pick up a rwd block and slop some pistons rods and a crank in it and slap it in my car so i know its good to go
Old Sep 5, 2007 | 11:37 AM
xnissan240x's Avatar
Fishes more than you
allot of the stuff is different! no im not a fanboy, yes i have experience with the fwd sr and rwd sr. all the mounting areas are different. it will not work.bell housing bolt locations are even different i believe.
Old Sep 5, 2007 | 11:42 AM
keaser06's Avatar
TR = Drama = LOL
ok thats the kind of answer i was looking for..a little more detailed would be good tho.. i would really like to see pics or something so that i can compare to know 100% sure it wont work.. because the oil and coolant lines for the turbo are the same i know that. and i believe they use same pistons, rods and crank.. so i dunno im thinking about ordering another motor putting it in and then rebuilding motor i have..
Old Sep 5, 2007 | 12:56 PM
Superluminal's Avatar
The Cyber Brain
You can use the internals of a RWD SR20DET just fine. The mounting points and the bellhousing pattern is different I believe, as is accessory components (i.e. power steering, A/C, alternator, etc.)
Old Sep 5, 2007 | 07:35 PM
keaser06's Avatar
TR = Drama = LOL
thanks thanks.. yeah i know the mounting points a diff now.. thanks guys..
Old Sep 6, 2007 | 06:10 AM
cagedeyecam's Avatar
AERODYNAMIC WHEN I FIGHT
im dumb.
Old Sep 6, 2007 | 06:14 AM
scott hutch's Avatar
^reading>you
