Integra coolant bleed valve location?
Hey anyone have any idea where the bleed valve to release air from the water system is on a regular b18 non vtec engine. In the haynes manual it says it's on the thermostat housing(there's a pictures where it shows where it is on a gsr.....lol) but i can't see it anywhere.........LMK if you have the answer. also this is NOT the drain plug i'm referring to I'm referring to the coolant bleed valve you would use to bleed air out of coolant system....... thanks alot....
oh ok but i mean if it never comes on....and i replaced the fuse, the relay is good, i tested the fan that's good, and i replaced the coolant temp sensor... wtf else can it be....it hasn't heated up or overheated yet, i just notice boiling in my reservior tank....
Im not saying your wrong but my bleeder valve on my b16 is on the thermostat housing, but a LS could b different, to make life simple just bleed the way I posted above u cant go wrong
