need alittle help
Old Jun 3, 2007 | 05:32 PM
kushracing's Avatar
Default need alittle help
my friend just got a b18b jdm sawp n is having some problems geting it to start i think it might be the fule injectors r not giveing out fule n when we spray starter flued in, it starts up n dies out
Old Jun 3, 2007 | 05:47 PM
Outkasted24's Avatar
** I ♥ Old Skool **
Are you getting spark?
Is the motor timed correctly?
Is the fuel pump working? (carefully unbolt the FPR and see if there is fuel in the rail)
You have the proper wire harness and ECU?
What car is this swap in?
Where in NPR are you?
My Flickr
slam.poke.drop.tuck.dope
Old Jun 3, 2007 | 05:50 PM
My Honda Is Slow's Avatar
No really,....it is
what car are you swapping into?
Originally Posted by Cold_Beer
JDM is gay, speed holes rock. /thread
35 mpg...... with the ac on bitches!
I got V-TECH AND HEADERS!
Old Jun 3, 2007 | 06:33 PM
LShatch98's Avatar
i love making you mad <3
that happen to my bro he had a problem with his throttle body his would start and die out but he is supercharged
Old Jun 3, 2007 | 08:45 PM
npr88crxsi's Avatar
its my car its a crx it had a b18a1 in it before this obd0 this jdm motor is obd1 the motor yes is timed it is getting spark and the fuel pump worked fine with the other motor we put in the jumper harness for the distributer it seems like its not gettin fuel though i live off little and 54 and the wiring and ecu is obd0
Old Jun 4, 2007 | 04:06 AM
tampabitches's Avatar
TR Balla Donor Supreme
so your running an obd1 distributer on an obd0 computer that your problem. an obd1 dizzy is different from and obd0. the only way you can run the obd1 is if you get a jumper harness and obd1 ls computer a then you should be fine. but since you had an ls in it before your old dizzy should work on that motor with no problem. someone correct me if i wrong. but change the dizzy and it should start no problem
91 CIVIC SEDAN LX TRADED
91 CIVIC HATCH B16A DX TRADED
97 CHEVY S10 ON BAGGES TRADED
98 CIVIC COUPE HX TRADED
91 CIVIC SEDAN EX TRADED
91 ACURA INTEGRA LS SOLD
91 CIVIC HATCH DX TRADED
93 FORD 150 XLT GOT STOLEN
92 ACURA INTEGRA LS TRADED
97 CHEVY 1500 350 TRADED
87 MAZDA B2000 TRADED
92 CIVIC SEDAN LX TRADED
92 CB7 LX SOLD
96 CHEVY S10 SOLD
92 FORD EXPLORER 4X4 TRADED
96 FORD F150 XLT TRADED
93 ACURA INTEGRA TRADED
95 FORD RANGER 4.0 TRADED
95 CHEVY S10 4X4 SOLD
Old Jun 4, 2007 | 09:05 AM
npr88crxsi's Avatar
so i need to get an obd0 ecu and an obd0 jumper harness and if i put my obd0 dizzy on there for know does it matter if i run the obd1 injecters or do i have to use the obd0 ones??
Old Jun 4, 2007 | 09:06 AM
npr88crxsi's Avatar
i have a jumper harness that goes from the dizzy i definatley need the ecu jumper harnees 2
Old Jun 4, 2007 | 09:22 AM
npr88crxsi's Avatar
i mean obd1
