please share your experiences.....
Old Apr 10, 2007 | 11:22 AM
madmanmaigret's Avatar
mad like crazy not angry
Default please share your experiences.....
i am about to change the clutch out on my 96 hatch. what are the things that are commonly forgotten? i will be replacing the flywheel also. what weight flywheel do i want for a stock car? i see a lot of 8lb flywheels but i think stock is 16lb. what do i use? what are common problems? any special tools besides clutch alignment tools? how much fluid do i need? DOT 3 the best to use? (keep in mind this is stock, but driven hard) what are some good local places that will sell a clutch/flywheel combo inexpensively (not CHEAP just inexpensive)? thanks guys/girls..... -kyle
I AM THE MADMAN
Old Apr 10, 2007 | 12:18 PM
custom240sx's Avatar
DC Crew Member #1
Fidanza flywheel ftw...deff. look into getting a lightweight flywheel if you still want to look stock but be faster.
Old Apr 10, 2007 | 12:21 PM
envee's Avatar
Green with Envy
you don't need anything lighter than 11 or 12 lbs for normal street driven cars. any thing less is going to change your stop and go traffic feel.
http://www.cardomain.com/ride/2931273
'06 Mazdaspeed 6
L3-VDT
'02 S2000... Sold
F20c
'93 Civic dx... Sold
B18C1
'95 4dr. GSR... Sold
B18C1 Supercharged
'95 LS... Sold
Originally Posted by shamoo
I have no problems punching a 10 year old in the face if they dented my car with intent.
Old Apr 10, 2007 | 12:54 PM
i thoght you could go too light. why do they sell em so light? because people don't know? where to buy etc.
I AM THE MADMAN
Old Apr 10, 2007 | 01:30 PM
Todd's90's Avatar
0711, USMC
yes, don't go to light, you will regret. when installing the flywheel and clutch make sure you use proper torque specs for both the flywheel and the clutch, when tightening the clutch to the flywheel only turn each bolt a couple turns at a time and use a star pattern, keep tightening untill the fingers of the clutch plate are all even, keep in mind the torque specs. properly lube the bearing and clutch fork. one of the hardest parts of getting the tranny back on is lining up the spline on the tranny and clutch. make sure your jack is adequate! Tools: torque wrench, breaker bar, and all the other standard tools. if I remember correctly you never need to open up the clutch line for any reason, the slave cylinder should unbolt from the tranny and never be a problem. Good luck !
Look at this pic, this is on my eclipse but the idea is the same, Make sure the fingers on the pressure plate are all even like on my clutch !! as you tighten the bolts on the clutch the fingers nearest the bolt you are tightening will be pushed in toward the flywheel, if you turn any of the bolts to much at one time then you could damage the pressure plate.
1990 GS-T
1990 GST
2004 BMW 325i
Old Apr 10, 2007 | 01:42 PM
what is stock flywheel weight? i found an exedy clutch/flywheel combo and called they said the flywheel was 22lbs?
I AM THE MADMAN
Old Apr 10, 2007 | 01:44 PM
^ here it is eBay Motors: EXEDY Clutch & OEM Flywheel 92-04 CIVIC / DEL SOL SOHC (item 150110731234 end time Apr-18-07 19:15:41 PDT)
I AM THE MADMAN
Old Apr 10, 2007 | 01:45 PM
is this too much? good price for exedy? i just want stock. hopefully swap before too long!
I AM THE MADMAN
Old Apr 10, 2007 | 02:08 PM
Todd's90's Avatar
0711, USMC
thats the same clutch I am using, works great.
1990 GS-T
1990 GST
2004 BMW 325i
Old Apr 10, 2007 | 02:12 PM
good price? everything i need?
I AM THE MADMAN
