Distributor Question
Ive Got A 91 Crx With A 90 Block And A 93 Head(d-series) And Its Leaking Oil From The Distributor So I Replaced The O-ring On It. It Is Still Leaking So I Went To Hondaland And Talk To A Guy Who Said It Is Because The Head Is Obd1 And The Distributor Is Obd0. So My Question Is Is That True, And How Would I Go About Fixing This Problem.
They say when a shark attacks you're supposed to punch him in the face. Then what, poke him in the eye with your nub.
Unless there is some wobble when you push in the distributor, it
should not be affecting an oil leak.
When a new o-ring doesn't seal, some people take the red high-temp gasket sealer, and apply it with their finger into and
around the rubber o-ring.-Bob
there is a seal inside the distributor sub assembly that is known for leaking oil also. You can replace just that one seal for like 8 bucks from honda if they still sell those seals seperatly. 9/10 that is what your problem is. That or find another sub-assembly that doesn't leak oil. My opnion is to go see if you can get a new seal and replace that part.
*should have stated this first, pull your cap off and see if oil is inside the cap or leaking around the cap area, that is usually a sign of that sub-assembly seal leaking oil.
