Feelin Horny!
Old Mar 7, 2007 | 03:46 PM
Cecil's Avatar
gone fishin
Default Feelin Horny!
So I asked www.hornblasters.com to put together a custom Train Horn for my truck.
It arrived today and I will be doing the install this weekend.
Here it is:
100% duty cycle 200psi compressor, 5 gallon 4 port tank, 4 horns, 1/2 valve
// it is set up as an on-board air supply as well //
I tested the horns with 120psi and they are brutally loud.
Old Mar 8, 2007 | 04:07 AM
tphitterlude92's Avatar
make a video when its done
2002 ranger going off road
15" rockcrawlers and 31" bfg all terrains.
8kHID's
line-x
and much more
Old Mar 8, 2007 | 08:22 AM
DANGERANGER's Avatar
Shop Bitch
Yeah Matts kit will scare you.
I carry all this stuff in stock if anyone is interested. I have 3 diiferent Viair compressors and 2-12 gal tanks in stock.
Call me if interested, info below.
thanx
Old Mar 8, 2007 | 08:26 AM
Presidential_Detail's Avatar
aka The Twanksta!
Which Vaair is that? I had the 450C and basically the same kit you have. Where do you plan to mount the horns, I see you have a F-series is that what its goin on?
A little tip that I found out, if you have them parallel to the ground but angled just slighty towards the ground and facing under the truck from the back(under truck bed) will make them SUPER loud.
Visit Our Site - Presidential Automotive Detailing
Authorized CQuartz FINEST Installer
Old Mar 8, 2007 | 09:08 AM
Cecil's Avatar
gone fishin
Part Number: VA380C
Voltage: 12 volts
Max Amperage: 16 amps
Maximum Operating Temperature: 158 ş F
Minimum Operating Temperature: 40 ş F
Maximum Duty Cycle: 100 %
Maximum Pressure: 200 PSI
CFM @ 0 PSI: 1.49 CFM
CFM @ 100 PSI: 0.81 CFM
Length: 9.00"
Height: 7.00"
Width: 4.00"
Weight: 8.00 lbs
Viair 380C 12V Air Compressor is a truly-rated continuous duty, 12-volt, 200 PSI compressor. It is capable of filling a 5-gallon tank from 165 PSI to 200 PSI in 3-1/2 minutes consistently, while never pulling more than 16 amps of power (@ 13.8 volts). It is the choice for those who wish to keep the strain on their vehicles’ charging systems to a minimum. Features include a standard 1/4” stainless steel braided leader hose with inline check valve and insulated wiring for simple installation.
This compressor has a factory rated working pressure of 200 PSI. Not only that but it has a duty cycle of 100% @ 100PSI and 55% @ 200PSI.
Old Mar 8, 2007 | 09:11 AM
Cecil's Avatar
gone fishin
As for the location, I have been kicking around a couple of ideas:
1 - In the bed. Putting the tank & compressor in the tool box with the horns mounted under the tool box facing to the rear.
2 - Under the truck, mounting most everything to the frame, facing forward.
Keep in mind.... this truck goes off-road and tends to get real muddy.... thus my reservation about having them underneath.
Old Mar 8, 2007 | 09:43 AM
aka The Twanksta!
1 - In the bed. Putting the tank & compressor in the tool box with the horns mounted ondure the tool box facing to the rear.
Yeah, I would keep them in the bed then if you go offroading a bit. People also put them in the front grill area facing downwards.
Old Mar 8, 2007 | 12:39 PM
Cecil's Avatar
gone fishin
No room in the grille either..... kinda sucks
Any ideas where I can score 1/2" steel braided air lines?
Old Mar 8, 2007 | 05:01 PM
jriggs's Avatar
is better than you™
Alamo piping or hoses or something to that effect its in ybor. great people and good prices. they will make custom fittings and lengths for you to make everything right.
Old Mar 8, 2007 | 06:04 PM
killerMikeD's Avatar
Lethal Fabrication.com
Amazon hose and rubber company on 41 near 60 can make them as well
Lethal Fab
